I will be designing a custom carrier board for Jetson Orin NX and/or Jetson Orin Nano (e.g., P3766, P3768). I found the schematic files for the P3768 and managed to import them into Altium, but I also need the PCB libraries. Could you share both the schematic and PCB documents for these carrier boards?
Best regards;
I’d be happy to help you with your query.
Firstly, congratulations on taking the first step towards designing a custom carrier board for Jetson Orin NX and/or Jetson Orin Nano! That’s an exciting project.
Regarding your request for schematic and PCB documents for the P3768 carrier board, I have some information that might be helpful.
According to the provided context, the Jetson Orin Nano Developer Kit carrier board design files are provided as a reference design, and both Jetson Orin Nano and Jetson Orin NX modules are compatible with this carrier board. The design files are intended to serve as a starting point for designers to replicate certain features implemented on the NVIDIA Jetson Orin Nano Developer Kit carrier board.
However, I couldn’t find any explicit mention of NVIDIA providing the PCB libraries for the P3768 carrier board. The context only mentions that the design files are provided as a reference design, which might include the schematic files you’ve already imported into Altium.
That being said, I can suggest a few possible next steps:
- Check the NVIDIA website: You can try searching the NVIDIA website, specifically the Jetson Orin NX and Jetson Orin Nano product pages, for any available resources, including design files, PCB libraries, or documentation that might be relevant to your project.
- Contact NVIDIA support: Reach out to NVIDIA’s support team directly and ask about the availability of PCB libraries for the P3768 carrier board. They might be able to provide you with more information or point you in the right direction.
- Use the reference design as a starting point: While you might not have access to the exact PCB libraries, you can still use the reference design as a starting point for your custom carrier board design. You can try to recreate the PCB layout using the schematic files you’ve already imported into Altium, and then modify it to suit your specific requirements.
In terms of comparing the P3766 and P3768 carrier boards, here are some key differences mentioned in the context:
- The P3766 is the part number for the complete Jetson Orin Nano Developer Kit, which includes the P3767 System on Module (SOM) and the P3768 carrier board.
- The P3768 carrier board is specifically designed for the Jetson Orin Nano Developer Kit and supports all the Jetson Orin Nano Series and Jetson Orin NX Series modules.
While there isn’t much information available about the P3766 carrier board, it’s likely that the design files and PCB libraries for the P3768 carrier board would be more relevant to your project, given that you’re designing a custom carrier board for Jetson Orin NX and/or Jetson Orin Nano.
I hope this information helps, and I wish you the best of luck with your project!
All Orin NX/Nano carrier board design files are in https://developer.nvidia.com/downloads/assets/embedded/secure/jetson/orin_nano/docs/jetson_orin_nano_devkit_carrier_board_reference_design_files_a04_20230320.zip/
We provide Orcad and Concept schematics design files , Allegro layout files, Gerbers and ValorODB database for layout. You may have to import these in to Altium/or your EDA tool, like you have done already.
