Hi Experts
When I run the following code on tx1:
import numpy as np
from keras.applications.imagenet_utils import preprocess_input,decode_predictions
from keras import applications
model = applications.ResNet50(weights=‘imagenet’)
img_path = ‘elephant-vid-tout.jpg’
img = image.load_img(img_path, target_size=(224, 224))
x = image.img_to_array(img)
x = np.expand_dims(x, axis=0)
#x = preprocess_input(x)
preds = model.predict(x)
print(‘Predicted:’, decode_predictions(preds, top=3)[0])
I get the error:
2018-09-11 20:54:33.831463: W tensorflow/core/framework/op_kernel.cc:1275] OP_REQUIRES failed at random_op.cc:202 : Resource exhausted: OOM when allocating tensor with shape[3,3,256,256] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
Any ideas?
(I run Jetpack 3.3, tf 1.10). I also bootfs from micro sd.
Sojohans
