[Resources] Build Training-Ready Physical AI Datasets With Two Prompts
Need more examples of rare events or defects? This tutorial shows how to use your coding agent with NVIDIA Cosmos Data Factory to curate, augment, generate, and label physical AI training data.
First, ask your coding agent to clone the CDF Orchestration repository and run preflight and setup. Then prompt it to run the blueprint for your data and use case.
Choose from five blueprints:
You can also use the six core agent skills independently or combine them for your own workflow.
📖 Read the technical blog
🧑‍💻 Explore the CDF blueprints and skills
📺 Watch the Cosmos Labs livestream with Voxel51 and Encord
📺 Watch the tutorial video
Which data gap are you trying to close? Share your use case, input data, or current blocker below or in the Cosmos Discord channel.
