device: Jeston orin Nano developer kit
number :2
action: clone the total system of device A to device B
Instructions :
command:
sudo ./tools/backup_restore/l4t_backup_restore.sh -r jetson-orin-nano-devkit
Error:
Waiting for target to boot-up…
Waiting for device to expose ssh …RTNETLINK answers: File exists
Device has booted into initrd. You can ssh to the target by the command:
$ ssh root@fe80::1%ens160u1
Cleaning up…
Log is saved to Linux_for_Tegra/initrdlog/flash_3-2_0_20241021-014950.log
Run command:
ln -s /proc/self/fd /dev/fd && mount -o nolock [fc00:1:1::1]:/home/tom/.local/share/Trash/files/Linux_for_Tegra/tools/backup_restore /mnt && /mnt/nvrestore_partitions.sh -n
on root@fc00:1:1::2
/mnt/images ~
nvrestore_partitions.sh: Use the default nvpartitionmap.txt as the index file.
nvrestore_partitions.sh: You are trying to flash images from a board model that does not
match the current board you’re flashing onto.
i already flash device B to same jetson pack 5.1.1 as device A .because the 5.1.1 had deleted in SDK manager i use this method to flash
-c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
--showlogs --network usb0 jetson-orin-nano-devkit internal`Preformatted text`
my system is load in mvme0 device. both device is the same, i dont know why i can clone from A but cant flash to device B
restore log file
* Step 1: Build the flashing environment *
Create flash environment 0
~/.local/share/Trash/files/Linux_for_Tegra/bootloader ~/.local/share/Trash/files/Linux_for_Tegra
Finish creating flash environment 0.
* Step 2: Boot the device with flash initrd image *
~/.local/share/Trash/files/Linux_for_Tegra/temp_initrdflash/bootloader0 ~/.local/share/Trash/files/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0004-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0004-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0004-p3768-0000-a0.dtb" --secondary_gpt_backup --bct_backup --boot_chain A --instance 3-2
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.2509 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.2509 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.2509 ] rcm boot with presigned binaries
[ 0.2531 ] tegrarcm_v2 --instance 3-2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.3715 ] BR_CID: 0x80012344705DD8213C00000018FE80C0
[ 0.4803 ] Sending bct_br
[ 0.4804 ] Sending mb1
[ 0.5573 ] Sending psc_bl1
[ 0.7766 ] Sending bct_mb1
[ 0.9411 ] Generating blob for T23x
[ 0.9455 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.9468 ] The number of images in blob is 18
[ 0.9476 ] blobsize is 65788654
[ 0.9477 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3182656
[ 1.0398 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 1.0403 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 1.0409 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 1.0413 ] Not supported type: mb2_applet
[ 1.0415 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 437984
[ 1.0420 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[ 1.0425 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 1.0484 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 1.0515 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1047936
[ 1.0528 ] Added binary blob_tegra234-bpmp-3767-0004-3509-a02_with_odm_sigheader.dtb.encrypt of size 199872
[ 1.0531 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 1.0534 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 1.0537 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 1.0539 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 1.0541 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[ 1.0550 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 1.0553 ] Added binary blob_boot0.img of size 47724544
[ 1.0965 ] Added binary blob_tegra234-p3767-0004-p3768-0000-a0.dtb of size 345470
[ 1.7321 ] tegrarcm_v2 --instance 3-2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 1.8723 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 1.9560 ] Sending bct_mem
[ 1.9840 ] Sending blob
[ 6.8201 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Cleaning up...
