Recently, I updated the JetPack on my Orin Nano from JetPack 5 to JetPack 6. After the update, I noticed that a model I had previously running (a RetinaNet model trained with TAO Toolkit 5.3) no longer loads on the Triton server. The Triton server successfully converts the model from an ONNX file to model.plan
, but when it tries to load the model from model.plan
, it crashes unexpectedly without any additional information.
I tested this model again on the previous JetPack version with TensorRT 8.6, and everything works as expected. Are there any known changes in the new TensorRT version that might cause compatibility issues with TAO Toolkit’s RetinaNet model?
• Hardware: Orin Nano with JetPack 6
• Network Type: RetinaNet trained with Tao Toolkit
• How to reproduce the issue ?: Loading model into the triton server with TensorRT 10.04
Logs:
I1028 07:34:25.875463 1 shared_library.cc:112] “OpenLibraryHandle: /opt/tritonserver/repoagents/trtconverter/libtritonrepoagent_trtconverter.so”
I1028 07:34:25.876578 1 model_config_utils.cc:716] “Server side auto-completed config: "
platform: “tensorrt_plan”
input {
data_type: TYPE_FP32
dims: 3
dims: 160
dims: 320
output {
dims: 1
dims: 200
dims: 7
output {
dims: 1
dims: 1
dims: 1
default_model_filename: “model.plan”
model_warmup {
batch_size: 1
inputs {
key: “Input”
value {
dims: 3
dims: 160
dims: 320
random_data: true
backend: “tensorrt”
model_repository_agents {
agents {
parameters {
key: “./1/retinanet_balltracking_us_data.onnx”
value: " --fp16”
I1028 07:34:25.876814 1 model_lifecycle.cc:441] “AsyncLoad() ‘ball_tracking_v2-internal’”
I1028 07:34:25.876972 1 model_lifecycle.cc:472] “loading: ball_tracking_v2-internal:1”
I1028 07:34:25.877072 1 model_lifecycle.cc:441] “AsyncLoad() ‘ball_tracking_v2’”
I1028 07:34:25.877215 1 model_lifecycle.cc:472] “loading: ball_tracking_v2:1”
I1028 07:34:25.877338 1 model_lifecycle.cc:551] “CreateModel() ‘ball_tracking_v2-internal’ version 1”
I1028 07:34:25.877658 1 backend_model.cc:503] “Adding default backend config setting: default-max-batch-size,4”
I1028 07:34:25.877772 1 shared_library.cc:112] “OpenLibraryHandle: /opt/tritonserver/backends/tensorrt/libtriton_tensorrt.so”
I1028 07:34:25.881588 1 model_lifecycle.cc:551] “CreateModel() ‘ball_tracking_v2’ version 1”
I1028 07:34:25.881814 1 backend_model.cc:503] “Adding default backend config setting: default-max-batch-size,4”
I1028 07:34:25.906358 1 tensorrt.cc:65] “TRITONBACKEND_Initialize: tensorrt”
I1028 07:34:25.906433 1 tensorrt.cc:75] “Triton TRITONBACKEND API version: 1.19”
I1028 07:34:25.906443 1 tensorrt.cc:81] “‘tensorrt’ TRITONBACKEND API version: 1.19”
I1028 07:34:25.906452 1 tensorrt.cc:105] “backend configuration:\n{"cmdline":{"auto-complete-config":"true","backend-directory":"/opt/tritonserver/backends","min-compute-capability":"5.300000","default-max-batch-size":"4"}}”
I1028 07:34:25.906489 1 tensorrt.cc:187] “Registering TensorRT Plugins”
I1028 07:34:25.906536 1 logging.cc:49] “Registered plugin creator - ::BatchedNMSDynamic_TRT version 1”
I1028 07:34:25.906552 1 logging.cc:49] “Registered plugin creator - ::BatchedNMS_TRT version 1”
I1028 07:34:25.906566 1 logging.cc:49] “Registered plugin creator - ::BatchTilePlugin_TRT version 1”
I1028 07:34:25.906583 1 logging.cc:49] “Registered plugin creator - ::Clip_TRT version 1”
I1028 07:34:25.906613 1 logging.cc:49] “Registered plugin creator - ::CoordConvAC version 1”
I1028 07:34:25.906630 1 logging.cc:49] “Registered plugin creator - ::CropAndResizeDynamic version 1”
I1028 07:34:25.906644 1 logging.cc:49] “Registered plugin creator - ::CropAndResize version 1”
I1028 07:34:25.906658 1 logging.cc:49] “Registered plugin creator - ::DecodeBbox3DPlugin version 1”
I1028 07:34:25.906671 1 logging.cc:49] “Registered plugin creator - ::DetectionLayer_TRT version 1”
I1028 07:34:25.906684 1 logging.cc:49] “Registered plugin creator - ::EfficientNMS_Explicit_TF_TRT version 1”
I1028 07:34:25.906696 1 logging.cc:49] “Registered plugin creator - ::EfficientNMS_Implicit_TF_TRT version 1”
I1028 07:34:25.906710 1 logging.cc:49] “Registered plugin creator - ::EfficientNMS_ONNX_TRT version 1”
I1028 07:34:25.906723 1 logging.cc:49] “Registered plugin creator - ::EfficientNMS_TRT version 1”
I1028 07:34:25.906744 1 logging.cc:49] “Registered plugin creator - ::FlattenConcat_TRT version 1”
I1028 07:34:25.906762 1 logging.cc:49] “Registered plugin creator - ::GenerateDetection_TRT version 1”
I1028 07:34:25.906777 1 logging.cc:49] “Registered plugin creator - ::GridAnchor_TRT version 1”
I1028 07:34:25.906789 1 logging.cc:49] “Registered plugin creator - ::GridAnchorRect_TRT version 1”
I1028 07:34:25.906802 1 logging.cc:49] “Registered plugin creator - ::InstanceNormalization_TRT version 1”
I1028 07:34:25.906816 1 logging.cc:49] “Registered plugin creator - ::InstanceNormalization_TRT version 2”
I1028 07:34:25.906831 1 logging.cc:49] “Registered plugin creator - ::InstanceNormalization_TRT version 3”
I1028 07:34:25.906846 1 logging.cc:49] “Registered plugin creator - ::LReLU_TRT version 1”
I1028 07:34:25.906860 1 logging.cc:49] “Registered plugin creator - ::ModulatedDeformConv2d version 1”
I1028 07:34:25.906873 1 logging.cc:49] “Registered plugin creator - ::MultilevelCropAndResize_TRT version 1”
I1028 07:34:25.906888 1 logging.cc:49] “Registered plugin creator - ::MultilevelProposeROI_TRT version 1”
I1028 07:34:25.906900 1 logging.cc:49] “Registered plugin creator - ::MultiscaleDeformableAttnPlugin_TRT version 1”
I1028 07:34:25.906923 1 logging.cc:49] “Registered plugin creator - ::NMSDynamic_TRT version 1”
I1028 07:34:25.906936 1 logging.cc:49] “Registered plugin creator - ::NMS_TRT version 1”
I1028 07:34:25.906948 1 logging.cc:49] “Registered plugin creator - ::Normalize_TRT version 1”
I1028 07:34:25.906960 1 logging.cc:49] “Registered plugin creator - ::PillarScatterPlugin version 1”
I1028 07:34:25.906972 1 logging.cc:49] “Registered plugin creator - ::PriorBox_TRT version 1”
I1028 07:34:25.906984 1 logging.cc:49] “Registered plugin creator - ::ProposalDynamic version 1”
I1028 07:34:25.906995 1 logging.cc:49] “Registered plugin creator - ::ProposalLayer_TRT version 1”
I1028 07:34:25.907010 1 logging.cc:49] “Registered plugin creator - ::Proposal version 1”
I1028 07:34:25.907023 1 logging.cc:49] “Registered plugin creator - ::PyramidROIAlign_TRT version 1”
I1028 07:34:25.907034 1 logging.cc:49] “Registered plugin creator - ::Region_TRT version 1”
I1028 07:34:25.907044 1 logging.cc:49] “Registered plugin creator - ::Reorg_TRT version 2”
I1028 07:34:25.907054 1 logging.cc:49] “Registered plugin creator - ::Reorg_TRT version 1”
I1028 07:34:25.907065 1 logging.cc:49] “Registered plugin creator - ::ResizeNearest_TRT version 1”
I1028 07:34:25.907075 1 logging.cc:49] “Registered plugin creator - ::ROIAlign_TRT version 1”
I1028 07:34:25.907089 1 logging.cc:49] “Registered plugin creator - ::ROIAlign_TRT version 2”
I1028 07:34:25.907103 1 logging.cc:49] “Registered plugin creator - ::RPROI_TRT version 1”
I1028 07:34:25.907116 1 logging.cc:49] “Registered plugin creator - ::ScatterElements version 2”
I1028 07:34:25.907128 1 logging.cc:49] “Registered plugin creator - ::ScatterElements version 1”
I1028 07:34:25.907145 1 logging.cc:49] “Registered plugin creator - ::ScatterND version 1”
I1028 07:34:25.907156 1 logging.cc:49] “Registered plugin creator - ::SpecialSlice_TRT version 1”
I1028 07:34:25.907165 1 logging.cc:49] “Registered plugin creator - ::Split version 1”
I1028 07:34:25.907176 1 logging.cc:49] “Registered plugin creator - ::VoxelGeneratorPlugin version 1”
I1028 07:34:25.907398 1 tensorrt.cc:231] “TRITONBACKEND_ModelInitialize: ball_tracking_v2-internal (version 1)”
I1028 07:34:25.907501 1 shared_library.cc:112] “OpenLibraryHandle: /opt/tritonserver/backends/python/libtriton_python.so”
I1028 07:34:25.908526 1 model_config_utils.cc:1941] “ModelConfig 64-bit fields:”
I1028 07:34:25.908559 1 model_config_utils.cc:1943] “\tModelConfig::dynamic_batching::default_priority_level”
I1028 07:34:25.908566 1 model_config_utils.cc:1943] “\tModelConfig::dynamic_batching::default_queue_policy::default_timeout_microseconds”
I1028 07:34:25.908572 1 model_config_utils.cc:1943] “\tModelConfig::dynamic_batching::max_queue_delay_microseconds”
I1028 07:34:25.908578 1 model_config_utils.cc:1943] “\tModelConfig::dynamic_batching::priority_levels”
I1028 07:34:25.908583 1 model_config_utils.cc:1943] “\tModelConfig::dynamic_batching::priority_queue_policy::key”
I1028 07:34:25.908588 1 model_config_utils.cc:1943] “\tModelConfig::dynamic_batching::priority_queue_policy::value::default_timeout_microseconds”
I1028 07:34:25.908594 1 model_config_utils.cc:1943] “\tModelConfig::ensemble_scheduling::step::model_version”
I1028 07:34:25.908599 1 model_config_utils.cc:1943] “\tModelConfig::input::dims”
I1028 07:34:25.908604 1 model_config_utils.cc:1943] “\tModelConfig::input::reshape::shape”
I1028 07:34:25.908610 1 model_config_utils.cc:1943] “\tModelConfig::instance_group::secondary_devices::device_id”
I1028 07:34:25.908615 1 model_config_utils.cc:1943] “\tModelConfig::model_warmup::inputs::value::dims”
I1028 07:34:25.908620 1 model_config_utils.cc:1943] “\tModelConfig::optimization::cuda::graph_spec::graph_lower_bound::input::value::dim”
I1028 07:34:25.908626 1 model_config_utils.cc:1943] “\tModelConfig::optimization::cuda::graph_spec::input::value::dim”
I1028 07:34:25.908631 1 model_config_utils.cc:1943] “\tModelConfig::output::dims”
I1028 07:34:25.908636 1 model_config_utils.cc:1943] “\tModelConfig::output::reshape::shape”
I1028 07:34:25.908641 1 model_config_utils.cc:1943] “\tModelConfig::sequence_batching::direct::max_queue_delay_microseconds”
I1028 07:34:25.908647 1 model_config_utils.cc:1943] “\tModelConfig::sequence_batching::max_sequence_idle_microseconds”
I1028 07:34:25.908652 1 model_config_utils.cc:1943] “\tModelConfig::sequence_batching::oldest::max_queue_delay_microseconds”
I1028 07:34:25.908657 1 model_config_utils.cc:1943] “\tModelConfig::sequence_batching::state::dims”
I1028 07:34:25.908663 1 model_config_utils.cc:1943] “\tModelConfig::sequence_batching::state::initial_state::dims”
I1028 07:34:25.908668 1 model_config_utils.cc:1943] “\tModelConfig::version_policy::specific::versions”
I1028 07:34:25.908891 1 model_state.cc:317] “Setting the CUDA device to GPU0 to auto-complete config for ball_tracking_v2-internal”
I1028 07:34:25.908988 1 model_state.cc:363] “Using explicit serialized file ‘model.plan’ to auto-complete config for ball_tracking_v2-internal”
I1028 07:34:25.912464 1 python_be.cc:1618] “‘python’ TRITONBACKEND API version: 1.19”
I1028 07:34:25.912516 1 python_be.cc:1640] “backend configuration:\n{"cmdline":{"auto-complete-config":"true","backend-directory":"/opt/tritonserver/backends","min-compute-capability":"5.300000","default-max-batch-size":"4"}}”
I1028 07:34:25.912781 1 python_be.cc:1778] “Shared memory configuration is shm-default-byte-size=1048576,shm-growth-byte-size=1048576,stub-timeout-seconds=30”
I1028 07:34:25.913663 1 python_be.cc:2075] “TRITONBACKEND_GetBackendAttribute: setting attributes”
I1028 07:34:25.913910 1 python_be.cc:1879] “TRITONBACKEND_ModelInitialize: ball_tracking_v2 (version 1)”
I1028 07:34:25.916027 1 stub_launcher.cc:385] “Starting Python backend stub: exec /opt/tritonserver/backends/python/triton_python_backend_stub /models/ball_tracking_v2/1/model.py triton_python_backend_shm_region_ae800121-f883-4f3f-9123-55a4aa4cf3ee 1048576 1048576 1 /opt/tritonserver/backends/python 336 ball_tracking_v2 DEFAULT”
I1028 07:34:25.952927 1 logging.cc:46] “Loaded engine size: 33 MiB”
I1028 07:34:26.002538 1 logging.cc:49] “Local registry did not find NMSDynamic_TRT creator. Will try parent registry if enabled.”
I1028 07:34:26.002605 1 logging.cc:49] “Global registry found NMSDynamic_TRT creator.”
