Retraining SSD Mobilenet using custom dataset annotated in Roboflow (dusty-nv/pytorch-ssd)
Good day, I am struggling to execute the training script with my custom dataset. I have just over 3000 images that have been annotated using Roboflow and my goal is to deploy the trained model to my Jetson nano.
I am training on google colab and have ensured that my dataset was exported in Pascal VOC format (as required for custom datasets) with train, test and validate sets.
When I execute the following command:
!python train_ssd.py --dataset-type=voc --data=Project-3/ --model-dir=models/ --batch-size=4 --num-epochs=1
I get the following error message:
OSError: missing ImageSet file Project-3/ImageSets/Main/trainval.txt
It does appear that datasets exported from Roboflow do not have text files for labels. How could I alter my current dataset to ensure that it works with the code?
Hi, I saw this post: Having trouble setting up pytorch code for training ssd-mobilenet - #5 by francis.tse
It sounds like you’ll just need to copy all lines in the train.txt and val.txt files into a new trainval.txt file. The answer linked above also demonstrates the directory structure you’ll have the files end up in, so you know where to house trainval.txt
Hi, thanks for the suggestion. I had resolved the issue a while ago. Turned out that my directory structure was not correct. After moving things around a bit, it worked. Best regards.
Thank you for the help.
