Hi All,
I am trying to train the object detection model as per the steps mentioned in the below link. Once I created the dataset and tried running python3 train_ssd.py --dataset-type=voc --data= --model-dir= but I couldn’t find any such file train_ssd.py in that directory.
<img src="https://github.com/dusty-nv/jetson-inference/raw/master/docs/images/deep-vision-header.jpg" width="100%">
<p align="right"><sup><a href="pytorch-plants.md">Back</a> | <a href="../README.md#hello-ai-world">Next</a> | </sup><a href="../README.md#hello-ai-world"><sup>Contents</sup></a>
<br/>
<sup>Transfer Learning - Object Detection</sup></s></p>
# Collecting your own Detection Datasets
The previously used `camera-capture` tool can also label object detection datasets from live video:
<img src="https://github.com/dusty-nv/jetson-inference/raw/dev/docs/images/pytorch-collection-detect.jpg" >
When the `Dataset Type` drop-down is in Detection mode, the tool creates datasets in [Pascal VOC](http://host.robots.ox.ac.uk/pascal/VOC/) format (which is supported during training).
> **note:** if you want to label a set of images that you already have (as opposed to capturing them from camera), try using a tool like [`CVAT`](https://github.com/openvinotoolkit/cvat) and export the dataset in Pascal VOC format. Then create a labels.txt in the dataset with the names of each of your object classes.
## Creating the Label File
Under `jetson-inference/python/training/detection/ssd/data`, create an empty directory for storing your dataset and a text file that will define the class labels (usually called `labels.txt`). The label file contains one class label per line, for example:
``` bash
This file has been truncated. show original
Can someone help me with this? Recently I cloned this repo and still am facing this issue. Is there any change in the path?
You can find the file here:
# train an SSD model on Pascal VOC or Open Images datasets
import os
import sys
import logging
import argparse
import datetime
import itertools
import torch
from torch.utils.data import DataLoader, ConcatDataset
from torch.utils.tensorboard import SummaryWriter
from torch.optim.lr_scheduler import CosineAnnealingLR, MultiStepLR
from vision.utils.misc import str2bool, Timer, freeze_net_layers, store_labels
from vision.ssd.ssd import MatchPrior
from vision.ssd.vgg_ssd import create_vgg_ssd
from vision.ssd.mobilenetv1_ssd import create_mobilenetv1_ssd
from vision.ssd.mobilenetv1_ssd_lite import create_mobilenetv1_ssd_lite
