zax
May 16, 2025, 9:43am
1
Jetpack version : 6.2
Board : custom designed
RGMII : KSZ9893RNXI-TR
I’m porting ksz9893 on our custom designed board for phy using with jetpack 6.2
I have check NV document and other topic on the forum
But it didn’t show any message in Dmesg,(such as ethernet@2310000)
I’ve ever porting another IC(ksz9031) on another custom designed board with Jp5.1.2
And it works fine, but it can’t work on Jp6.2 too
Here’s the dts for Jp512 with RGMII success
/*EQOS*/
ethernet@2310000 {
compatible="nvidia,nveqos";
status = "okay";
nvidia,mac-addr-idx = <0>;
nvidia,max-platform-mtu = <16383>;
nvidia,pause_frames = <0>;
phy-mode="rgmii-id";
phy-handle = <&rgmii_phy>;
/delete-node/ fixed-link;
fixed-link{
speed = <1000>;
full-duplex;
mdio {
compatible = "nvidia,eqos-mdio";
#address-cells = <1>;
#size-cells = <0>;
rgmii_phy: phy@7{
compatible= "ethernet-phy-ieee802.3-c22", "ethernet-phy-id0022.1620", "micrel,ksz9031";
reg = <7>;
device_type = "ethernet-phy";
nvidia,phy-rst-pdelay-msec = <224>;
nvidia,phy-rst-duration-usec = <10000>;
interrupt-parent = <&gpio>;
interrupts = <TEGRA234_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
micrel,reg-init = <0x3 0x12 0x7fff 0x880>;
micrel,copper-mode;
phandle = <0x21>;
//max-speed = <1000>;
Could you help to give me some suggestions for porting ksz9893 on Jp6.2 ?
I guess you didn’t modify correct location in the device tree.
Check your full dts converted back from dtb and it will tell.
zax
May 19, 2025, 3:49am
4
Yes, you’re right
The dts converted back from dtb show disabled
But I have check the ethernet@2310000 did not be used on other dts
Is there any place to modify it’s status?
any place could be fine if the final dtb would set it to enabled… I never memorize which file could be used to modify because that is meaningless thing if you know how device tree works…
zax
May 19, 2025, 9:50am
6
Thanks for help
I’ve enabled it by setting at the final dts
And here’s the error message
nvethernet 2310000. ethernet: Adding to tommu group 52
nvethernet 2310000. ethernet: failed to read skip mac reset flag, default o
nvethernet 2310000. ethernet: failed to read MDIO address
nvethernet 2310000. ethernet: setting to default DA bit mask
nvethernet 2310000. ethernet: failed to get phy reset gio error: -2
nvethernet 2310000. ethernet: Ethernet MAC address: 00:11:14:1a: 6b:7d
nvethernet 2310000. ethernet: Macsec not enabled
nvethernet 2310000. ethernet: Macsec: Reduced MTU: 1466 Max: 16383
nvethernet 2310000. ethernet: eth1 (HW ver: 53) created with 8 DMA channels
nvethernet 2310000. ethernet eth1: Link is Up - 1Gbps/Full - flow control off
I can see interface eth1 in ifconfig
, but I can’t ping 8.8.8.8 successfully
it shows connect: Network is unreachable
Here’s my dts now, according to log, reset ping may have some problem, but it seems not really matter
Could you give me some suggestions?
ethernet@2310000 {
status = "okay";
nvidia,mac-addr-idx = <1>;
// nvidia,phy-reset-gpio = <&gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
nvidia,phy-reset-gpios = <&pca6408_20 6 GPIO_ACTIVE_LOW>; //control by i2c-gpio
phy-mode = "rgmii-id";
/* 1:10G, 0:5G */
nvidia,uphy-gbe-mode = <1>;
/* 0:XFI 10G, 1:XFI 5G, 2:USXGMII 10G, 3:USXGMII 5G */
nvidia,phy-iface-mode = <0>;
// phy-handle = <&phy>; //no need for switch
fixed-link {
speed = <1000>;
full-duplex;
mdio {
#size-cells = <0>;
switch@1 {
// status = "okay";
compatible = "microchip,ksz9477";
reg = <1>;
// phy-mode = "rgmii";
nvidia,phy-rst-pdelay-msec = <224>; /* msec */
nvidia,phy-rst-duration-usec = <10000>; /* usec */
switch@2 {
// status = "okay";
reg = <2>;
What is this setting doing here? This is not a UPHY.
zax
May 20, 2025, 12:56am
8
Actually I’m not really sure about that
I’m not familiar with RGMII, so have some reference by document and forum
I add it according to the document
system
Closed
June 3, 2025, 12:57am
11
