I’m trying to use KSZ9896 as PHY on Jetson AGX Xavier custom board.KSZ9896 connected over RGMII interface on port 6 and I2C bus.I have modified dtsi and ported driver,but it didn’t work.
Please help to make ksz9896 work properly on Jetson AGX Xavier.Thanks a lot.
My dtsi is as follows,
ether_qos0: ether_qos@2490000 {
/* PTP_ref clock speed in MHz /
nvidia,ptp_ref_clock_speed = <312500000>;
/ rxq_enable_ctrl =
* 0x0 = Not enabled, 0x1 = Enabled for AV
* 0x2 = Enabled for Legacy, 0x3 = Reserved
nvidia,rxq_enable_ctrl = <2 2 2 2>;
nvidia,queue_prio = <0 1 2 3>;
nvidia,use_tagged_ptp;
nvidia,ptp_dma_ch = <3>;
nvidia,chan_napi_quota = <64 64 64 64>;
nvidia,pause_frames = <0>; /*0=enable, 1=disable */
nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 5) 0>;
nvidia,phy-max-frame-size = <16>; /* size in kbytes */
nvidia,eth_iso_enable = <1>; /*0=enable, 1=disable */
phy-mode = "rgmii-id";
phy-handle = <&switch0port5>;
mdytest = "madayi210914";
i2c@3160000 {
phy0: ksz9896@5f {
compatible = "microchip,ksz9896";
reg = <0x5f>;
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA194_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
status = "okay";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
label = "lan1";
port@1 {
reg = <1>;
label = "lan2";
port@2 {
reg = <2>;
label = "lan3";
port@3 {
reg = <3>;
label = "lan4";
port@4 {
reg = <4>;
label = "lan5";
switch0port5: port@5 {
reg = <5>;
label = "cpu";
ethernet = <ðer_qos0>;
fixed-link {
speed = <1000>;
full-duplex;
thermal-zones {
CPU-therm {
trips {
MAKE_EQOS_TRIP(m40, -40000, 5000);
MAKE_EQOS_TRIP(m5, -5000, 5000);
MAKE_EQOS_TRIP(p30, 30000, 5000);
MAKE_EQOS_TRIP(p65, 65000, 5000);
MAKE_EQOS_TRIP(p100, 100000, 5000);
cooling-maps {
MAP_EQOS(m40, 1);
MAP_EQOS(m5, 2);
MAP_EQOS(p30, 3);
MAP_EQOS(p65, 4);
MAP_EQOS(p100, 5);
};dmesg20200915.log (79.0 KB)
