Use ksz9897 to connect to jetson agx’s MDIO interface, but the switch network is not connected, can you help me see how to solve it? This is the driver for the KSZ9897: https://github.com/Microchip-Ethernet/EVB-KSZ9477/tree/master/KSZ/linux-drivers/ksz9897
@kayccc,Hello, can you help me look at this issue? Do you want to port the kernel or do you need to modify the device tree?I’m using the latest Jetson Linux 35.1.Thank you.
please check the document. Each PHY could be case by case. Better also consulting with PHY vendor to know what to check.
