We are trying to create a custom carrier for the AGX Xavier with a KSZ9897 switch chip connected to the RGMII/MDIO interface. We have found that the switch works independently from the AGX, but the PHY is not detected by the AGX’s MDIO bus, with the error “eth0: Could not attach to PHY” followed by “net eth0: eqos_open: Cannot attach to PHY (error: -19)” in the dmesg.
Our eqos device tree looks as follows:
ether_qos@2490000 {
compatible = “nvidia,eqos”;
reg = <0x00000000 0x02490000 0x00000000 0x00010000>;
reg-names = “eqos_base”;
interrupts = <0x00000000 0x000000c2 0x00000004 0x00000000 0x000000c3 0x00000004 0x00000000 0x000000be 0x00000004 0x00000000 0x000000ba 0x00000004 0x00000000 0x000000bf 0x00000004 0x00000000 0x000000bb 0x00000004 0x00000000 0x000000c0 0x00000004 0x00000000 0x000000bc 0x00000004 0x00000000 0x000000c1 0x00000004 0x00000000 0x000000bd 0x00000004>;
clocks = <0x00000004 0x00000120 0x00000004 0x00000020 0x00000004 0x00000022 0x00000004 0x00000021 0x00000004 0x00000023 0x00000004 0x00000008>;
clock-names = “pllrefe_vcoout”, “eqos_axi”, “eqos_rx”, “eqos_ptp_ref”, “eqos_tx”, “axi_cbb”;
resets = <0x00000005 0x00000011>;
reset-names = “eqos_rst”;
nvidia,local-mac-address = <0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000>;
iommus = <0x00000002 0x00000014>;
iommu-group-id = <0x00000002>;
dma-coherent;
nvidia,csr_clock_speed = <0x00000019>;
nvidia,iso_bw = <0x00014000>;
nvidia,rx_riwt = <0x0000003c>;
nvidia,rx_frames = <0x00000010>;
nvidia,slot_intvl_val = <0x0000007c>;
status = “okay”;
pinctrl-names = “idle”, “default”;
pinctrl-0 = <0x0000001d>;
pinctrl-1 = <0x0000001e>;
nvidia,ptp_ref_clock_speed = <0x12a05f20>;
nvidia,rxq_enable_ctrl = <0x00000002 0x00000002 0x00000002 0x00000002>;
nvidia,queue_prio = <0x00000000 0x00000001 0x00000002 0x00000003>;
nvidia,use_tagged_ptp;
nvidia,ptp_dma_ch = <0x00000003>;
nvidia,chan_napi_quota = <0x00000040 0x00000040 0x00000040 0x00000040>;
nvidia,pause_frames = <0x00000001>;
nvidia,phy-reset-gpio = <0x00000013 0x00000035 0x00000000>;
nvidia,phy-max-frame-size = <0x00000010>;
nvidia,eth_iso_enable = <0x00000001>;
phy-mode = “rgmii-id”;
phy-handle = <0x0000001f>;
vddio_sys_enet_bias-supply = <0x00000020>;
vddio_enet-supply = <0x00000020>;
phy_vdd_1v8-supply = <0x00000021>;
phy_ovdd_rgmii-supply = <0x00000021>;
phy_pllvdd-supply = <0x00000020>;
linux,phandle = <0x000000bc>;
eqos-cool-dev {
cooling-min-state = <0x00000000>;
cooling-max-state = <0x00000005>;
#cooling-cells = <0x00000002>;
linux,phandle = <0x00000070>;
prod-settings {
#prod-cells = <0x00000004>;
prod {
prod = <0x00000000 0x00008800 0x80000000 0x00000000 0x00000000 0x00008804 0x20000000 0x20000000>;
mdio {
compatible = “nvidia,eqos-mdio”;
#address-cells = <0x00000001>;
#size-cells = <0x00000000>;
ethernet-phy@0 {
reg = <0x00000000>;
phy_rst_lp_mode = <0x00000001>;
interrupt-parent = <0x00000013>;
interrupts = <0x00000034 0x00000008>;
marvell,reg-init = <0x00000003 0x00000012 0x00007fff 0x00000880>;
status = “okay”;
linux,phandle = <0x0000001f>;
fixed-link {
speed = <0x000003e8>;
full-duplex;
Checking /sys/bus/mdio_bus/devices/, no devices are detected.
Do you have any documentation that will help us bring up this PHY? Thank you.
