Hello
Where are the MDC and MDIO pins configured in device tree ? Or was it configured somewhere else?
I have replaced the original PHY chip with the Marvell 88E6352 chip now,the communication is not successful.
Hello
Please refer to this thread.
I have already seen this topic ,and I configed
CONFIG_NET_DSA=y
CONFIG_NET_DSA_MV88E6XXX=y
CONFIG_NET_DSA_MV88E6XXX_GLOBAL2=y
my driver mv88e6085 has appears under /sys/bus/mdio_bus/drivers.
but the network still doesnt work . So ,how can I read the chips register data through MDIO?
Please look at
TX2
hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-eqos.dtsi
Xavier
hardware/nvidia/platform/t19x/common/kernel-dts/t19x-common-platforms/tegra194-platforms-eqos.dtsi
It is where brcm/Marvell PHY registers some information for eqos driver.
This is the original device tree
ether_qos@2490000 {
/* PTP_ref clock speed in MHz */
nvidia,ptp_ref_clock_speed = <312500000>;
/* rxq_enable_ctrl = <rx0 rx1 rx2 rx3>
* 0x0 = Not enabled, 0x1 = Enabled for AV
* 0x2 = Enabled for Legacy, 0x3 = Reserved
nvidia,rxq_enable_ctrl = <2 2 2 2>;
nvidia,queue_prio = <0 1 2 3>;
nvidia,use_tagged_ptp;
nvidia,ptp_dma_ch = <3>;
nvidia,chan_napi_quota = <64 64 64 64>;
nvidia,pause_frames = <0>; /*0=enable, 1=disable */
nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 5) 0>;
nvidia,phy-max-frame-size = <16>; /* size in kbytes */
nvidia,eth_iso_enable = <1>; /*0=enable, 1=disable */
phy-mode = "rgmii-id";
phy-handle = <&phy0>;
mdio:mdio {
compatible = "nvidia,eqos-mdio";
#address-cells = <1>;
#size-cells = <0>;
phy0: ethernet-phy@0 {
reg = <0>;
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA194_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
marvell,copper-mode;
This is what I modified according to dsa.txt
ether_qos@2490000 {
phy-handle = <&switch0>;
mdio {
#size-cells = <0>;
switch0: switch0@0 {
compatible = "marvell,mv88e6352","marvell,mv88e6085";
#size-cells = <0>;
reg = <0>;
dsa,member = <0 0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
label = "lan0";
port@1 {
reg = <1>;
label = "lan1";
port@2 {
reg = <2>;
label = "lan2";
switch0port6:port@6 {
reg = <6>;
label = "cpu";
// ethernet = <&fec1>;
fixed-link {
speed = <100>;
full-duplex;
