Hi All,
I am integratng an Ethernet switch (Marvell 88E6390) to our AGX Xavier carrier board.
I modified tegra194-platforms-eqos.dtsi with following changes by refering to the file “kernel-5.10/Documentation/devicetree/bindings/net/dsa/marvell.txt”
ethernet@2490000 {
interrupts = <0 194 0x4>, /* common */
<0 186 0x4>, /* tx0 */
<0 190 0x4>; /* rx0 */
/* rxq_enable_ctrl = <rx0 rx1 rx2 rx3>
* 0x0 = Not enabled, 0x1 = Enabled for AV
* 0x2 = Enabled for Legacy, 0x3 = Reserved
nvidia,rxq_enable_ctrl = <2>;
nvidia,num-dma-chans = <1>;
nvidia,dma-chans = <0>;
nvidia,num-mtl-queues = <1>;
nvidia,mtl-queues = <0>;
nvidia,rx-queue-prio = <0x2>;
nvidia,tx-queue-prio = <0x0>;
/* 1=enable, 0=disable */
nvidia,pause_frames = <1>;
nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 5) 0>;
phy-mode = "rgmii-id";
phy-handle = <&phy>;
nvidia,max-platform-mtu = <16383>;
mdio {
compatible = "nvidia,eqos-mdio";
#address-cells = <1>;
#size-cells = <0>;
reginterrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA194_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
interrupt-controller;
#interrupt-cells = <2>;
phy: phy@0 {
compatible = "marvell,mv88e6190";
reg = <0>;
reset-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 5) 0>;
//reginterrupt-parent = <&tegra_main_gpio>;
//interrupts = <TEGRA194_MAIN_GPIO(G, 4) IRQ_TYPE_LEVEL_LOW>;
marvell,copper-mode;
/* Setup LED[2] as interrupt pin (active low) */
marvell,reg-init = <0x03 0x12 0x7fff 0x880>;
switch1phy0: switch1phy0@0 {
reg = <0>;
interrupt-parent = <&phy>;
interrupts = <0 IRQ_TYPE_LEVEL_HIGH>;
After using the new dtb, I cannot see any ethernet interface by command ifconfig.
The kernel log has been attached. I found there is an error when initialize the eqos.
"net eth0: failed to poll MAC Software reset"
Did I set the devicetree correctly and how to fix this error!?
kernel.log (109.0 KB)
Hi WayneWWW,
I added fixed link into devicetree but the issue was still exist.
ethernet@2490000 {
//phy-handle = <&phy>;
fixed-link {
speed = <10000>;
full-duplex;
mdio {
#size-cells = <0>;
phy: phy@0 {
reg = <0>;
reg = <0>;
Please see the attached kernel log .
kernel.log (111.6 KB)
ethernet@2310000 {
status = “okay”;
nvidia,mac-addr-idx = <0>;
//interrupts = <&tegra_main_gpio>;
//nvidia,phy-reset-gpio = <&tegra_main_gpio TEGRA234_MAIN_GPIO(G, 5) 0>;
phy-mode = “rgmii-id”;
nvidia,pause_frames = <0>;
nvidia,tx_usecs = <0x200>;
fixed-link {
speed = <1000>;
full-duplex;
Thank you for your response. However, we eventually found that the issue was due to the TX and RX being reversed. After correcting this, everything worked properly.
You’re welcome, I don’t think I’ve been of much help
@FrankPCP Is the problem resolved? I also use the 88e1512 Ethernet Pi as before, but I am using it with an 88e6390x Ethernet switch attached, but it is not connected to the mdio-bus.
我的问题未解决,我是根据论坛上一位开发者的设备树配置来配置的,RGMII直连JL6107SC交换机,一直卡在failed to poll MAC Software reset。追踪发现是卡在core_common.c的poll_check函数,*value = osi_readla(osi_core, addr)这句程序读的寄存器值一直为1,原因是什么还没有找到,pinmux、gpio和设备树反复改,均没有解决问题。我也很期待有大神能提供帮助
