I saw this thread:
[About xavier EQOS MAC to MAC] and it’s exactly the problem I have. Can you please give more details about the solution?
@liu.jialu I’m using also the Marvell 88E6321, and I can’t make the ethernet work. Can you please share the schematics connection between the ethernet switch and jetson xavier? I attached mine.
When I connect the xavier to my carrier board, I can see on scope that the 125MHz clock out from the switch is distorted, and the clock from the jetson to the switch is degraded - about half 0.8Vp-p, but it looks reasonable comparing to the other clock.
Can you help me please? could it be a software issue?
Thank you,
Efi
