Was forced update due to security. Was using 7.5 now we are 7.8 RHEL with 3.10.0-1127.18.2.el7.x86_64 as the kernel. Because of the infiniband card we use, we can’t use anything higher than mlnx-ofed-5.0-2.1.8.0. It installs fine but ib0 will not fire.
Related topics
| missing ifup-ib in latest release? | 2 | 1197 | December 3, 2018 | |
| infiniband interfaces are missing after server reboot | 3 | 612 | August 23, 2024 | |
| Updated RHEL7 kernel. Now openibd.service fails to start. Do I have to re-load the driver again? Is there a way to just update and not completely reinstall? Or is there some other issue? | 2 | 1257 | May 29, 2020 | |
| MLNX_OFED_LINUX installtion Error: Error: The current MLNX_OFED_LINUX is intended for rhel6.4 | 12 | 2728 | January 13, 2014 | |
| Infiniband network device ib0 doesn't exist | 1 | 2198 | April 8, 2022 | |
| ConnectX-3 firmware update | 11 | 1662 | December 11, 2018 | |
| The device does not seem to be present, delaying initialization (need ifup device manually) | 1 | 420 | December 24, 2020 | |
| Installation and fireware update problems | 6 | 1362 | March 22, 2013 | |
| Invalid module format when loading ib_* (RHEL 6.4) | 4 | 384 | July 13, 2013 | |
| Install MLNX OFED 4.7 (with "--upstream-libs" option) on CentOS 7.6 with kernel 4.20.0 caused MLNX NIC down | 2 | 705 | November 18, 2019 |
