missing ifup-ib in latest release?
Hi .. I have some old cluster nodes that were working fine under previous versions of CentOS 7 (I think it was CentOS 7.3 before update) but after doing a recent update to CentOS 7.5 I can’t seem to get the interface to come up. I reinstalled the latest MLNX_OFED drivers (MLNX_OFED_LINUX-4.3-3.0.2.1-rhel7.5-x86_64) which installed properly. I see the card in lspci and the kernel modules seem to be loaded as well. However, I can’t seem to bring up the interface. Doing an ifup I get this:
ifup ib0
ERROR : [/etc/sysconfig/network-scripts/ifup-eth] Device ib0 does not seem to be present, delaying initialization.
Which seemed weird to me that it was trying to use the ifup-eth code instead of the ifup-ib code to bring up the interface. When I looked for this file I don’t see it on the system with the mlnx_ofed software installed. If I don’t install mlnx_ofed and just leave the CentOS drivers installed the card comes up fine. I also notice this comes from the rdma-core package from CentOS:
rpm -qf /etc/sysconfig/network-scripts/ifup-ib
rdma-core-15-7.el7_5.x86_64
When I look at the mlnx_ofed installed machine I don’t see an rdma-core package…
rpm -qa | grep rdma
librdmacm-41mlnx1-OFED.4.2.0.1.3.43302.x86_64
librdmacm-utils-41mlnx1-OFED.4.2.0.1.3.43302.x86_64
librdmacm-devel-41mlnx1-OFED.4.2.0.1.3.43302.x86_64
So I’m wondering if I am missing something with this? Previous versions I didn’t seem to have any issues with getting it installed and using it. Anyone have some advice as to what I should look at further to figure this out? Thanks,
Hi ,
Could you please check if ib0 interface found under “ifconfig -a” ?
If not, i suggest the following:
  1. invoke mst start → mst status → ifconfig and check again
  2. Try to restart the interfaces:
  • /etc/init.d/openibd restart
  • opensm start or start the SM on the switch
  1. If the above still not working , create interface manually :
vi /etc/sysconfig/network-scripts/ifcfg-ib0
NAME=“ib0”
DEVICE=“ib0”
ONBOOT=yes
BOOTPROTO=static
TYPE=Infiniband
IPADDR=
Thanks,
Samer
Hi… not sure why this came up and sent me a message today about it. Yea that solution didn’t work as the IB interfaces aren’t working properly. I suspect it’s related to this:
and
I discovered this problem with the kernel after a few weeks of posting this. I need to look back at this and see if this issue has been fixed in the latest kernel or if it’s still broken.
