Riva doesn't work after Jetson restart
Hi
Hardware - Jetson AGX Orin Dev Kit (64GB)
Operating System - JetPack 5.1.1
Riva Version - 2.12.0
I had Riva 2.12.0 working yesterday.
However, I tried it today and my Riva became unresponsive.
I’m talking into the microphone.
Below are the steps I tried.
jetson@ubuntu:~/Desktop/work/riva/riva_quickstart_arm64_v2.12.0$ sudo bash riva_start.sh
Starting Riva Speech Services. This may take several minutes depending on the number of models deployed.
Waiting for Riva server to load all models...retrying in 10 seconds
Riva server is ready...
Use this container terminal to run applications:
root@18e85898ce6e:/opt/riva#
Then I ran the following locally:
jetson@ubuntu:~/Desktop/work/riva/riva_quickstart_arm64_v2.12.0/examples$ python3 transcribe_mic.py --language-code ja-JP
ALSA lib pcm_dmix.c:1089:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'cards.USB-Audio.pcm.hdmi.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib conf.c:4732:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5220:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM hdmi
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2642:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
ALSA lib pcm_dmix.c:1024:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Yesterday, when I spoke to the USB microphone, the message was displayed as text.
However, no matter how many times I talk today, the text does not appear.
The sample software in the Riva server container works, so I guessed that the USB microphone could not be input.
help me.
I have a presentation coming up…
Hi
I was able to solve it by looking at the following page.
It was a problem that depends on the setting of the USB microphone used.
Thank you
Thanks for sharing.
