Hardware - Orin AGX devkit
Hardware - CPU
Operating System Ubuntu (jetpack 6.0
Riva Version Latest
TLT Version (if relevant)
How to reproduce the issue ?
Most likely something I have not done, if someone cares to comment :)
Using:
dusty-nv/jetson-containers/tree/master/packages/audio/riva-client/
24: USB Condenser Microphone: Audio (hw:2,0) (inputs=1 outputs=0 sampleRate=44100)
root@io:/opt/riva/python-clients# python3 scripts/asr/transcribe_mic.py --input-device=24 --sample-rate-hz=44100
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition ‘cards.0.pcm.front.0:CARD=0’
ALSA lib conf.c:5178:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5701:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition ‘cards.0.pcm.surround51.0:CARD=0’
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition ‘cards.0.pcm.surround40.0:CARD=0’
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition ‘cards.0.pcm.surround71.0:CARD=0’
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition ‘cards.0.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2’
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_dmix.c:1032:(snd_pcm_dmix_open) unable to open slave
File “/opt/riva/python-clients/scripts/asr/transcribe_mic.py”, line 75, in
main()
File “/opt/riva/python-clients/scripts/asr/transcribe_mic.py”, line 65, in main
riva.client.print_streaming(
File “/usr/local/lib/python3.10/dist-packages/riva/client/asr.py”, line 197, in print_streaming
for response in responses:
File “/usr/local/lib/python3.10/dist-packages/riva/client/asr.py”, line 338, in streaming_response_generator
for response in self.stub.StreamingRecognize(generator, metadata=self.auth.get_auth_metadata()):
File “/usr/local/lib/python3.10/dist-packages/grpc/_channel.py”, line 542, in next
return self._next()
File “/usr/local/lib/python3.10/dist-packages/grpc/_channel.py”, line 968, in _next
raise self
grpc._channel._MultiThreadedRendezvous: <_MultiThreadedRendezvous of RPC that terminated with:
status = StatusCode.UNAVAILABLE
details = “failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:50051: Failed to connect to remote host: Connection refused”
debug_error_string = “UNKNOWN:Error received from peer {created_time:“2024-03-07T17:58:53.495292465+00:00”, grpc_status:14, grpc_message:“failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:50051: Failed to connect to remote host: Connection refused”}”
