i ve been trying to use the streaming automatic speech recognition, however it crashes every time i use streaming asr. it works normally when using offline speech recognition though. if logs are needed let me know.
also here is the config.sh of the server:
config.sh (13.3 KB)
here are the logs: the riva server is running on an A100 and the client on a desktop with ubuntu linux:
ALSA lib pcm_dsnoop.c:601:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:1032:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card ‘card’
Input audio devices:
13: HD-Audio Generic: ALCS1200A Analog (hw:2,0)
15: HD-Audio Generic: ALCS1200A Alt Analog (hw:2,2)
17: pulse
18: default
None
18
SystemError: PY_SSIZE_T_CLEAN macro must be defined for ‘#’ formats
Hi @aggelosioannidhs21
Thanks for your interest in Riva
Apologies you are facing issue
I will try to reproduce the issue from my end
Request to kindly provide the python script/notebook used for ASR Streaming inference
