After solving the cuda library problem, i commit new version of image. and run the riva_start.sh. following result:
nvidia@nvidia-orin-desktop:~/exp/riva_quickstart_arm64_v2.0.0$ ./riva_start.sh
Starting Riva Speech Services. This may take several minutes depending on the number of models deployed.
a613d91d9e5e2a54d3aeba9f3925753c109255567602273e20181e89e6758d56
I0602 03:31:30.375615 12 pinned_memory_manager.cc:240] Pinned memory pool is created at ‘0x205227000’ with size 268435456
I0602 03:31:30.375802 12 cuda_memory_manager.cc:105] CUDA memory pool is created on device 0 with size 67108864
I0602 03:31:30.380195 12 model_repository_manager.cc:994] loading: citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming:1
I0602 03:31:30.480413 12 model_repository_manager.cc:994] loading: citrinet-256-en-US-streaming-feature-extractor-streaming:1
I0602 03:31:30.491002 12 ctc-decoder-library.cc:21] TRITONBACKEND_ModelInitialize: citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming (version 1)
W:parameter_parser.cc:120: Parameter forerunner_start_offset_ms could not be set from parameters
W:parameter_parser.cc:121: Default value will be used
W:parameter_parser.cc:120: Parameter max_num_slots could not be set from parameters
W:parameter_parser.cc:120: Parameter num_tokenization could not be set from parameters
I0602 03:31:30.493238 12 backend_model.cc:255] model configuration:
“name”: “citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming”,
“platform”: “”,
“backend”: “riva_asr_decoder”,
“version_policy”: {
“latest”: {
“num_versions”: 1
“max_batch_size”: 1,
“input”: [
“name”: “CLASS_LOGITS”,
“data_type”: “TYPE_FP32”,
“format”: “FORMAT_NONE”,
“dims”: [
-1,
1025
“is_shape_tensor”: false,
“allow_ragged_batch”: false,
“optional”: false
“name”: “END_FLAG”,
“data_type”: “TYPE_UINT32”,
“dims”: [
1
“optional”: false
“name”: “SEGMENTS_START_END”,
“data_type”: “TYPE_INT32”,
“dims”: [
-1,
2
“optional”: false
“name”: “CUSTOM_CONFIGURATION”,
“data_type”: “TYPE_STRING”,
“dims”: [
-1,
2
“optional”: false
“output”: [
“name”: “FINAL_TRANSCRIPTS”,
“dims”: [
-1
“label_filename”: “”,
“name”: “FINAL_TRANSCRIPTS_SCORE”,
“dims”: [
-1
“name”: “FINAL_WORDS_START_END”,
“dims”: [
-1,
2
“name”: “PARTIAL_TRANSCRIPTS”,
“dims”: [
-1
“name”: “PARTIAL_TRANSCRIPTS_STABILITY”,
“dims”: [
-1
“name”: “PARTIAL_WORDS_START_END”,
“dims”: [
-1,
2
“batch_input”: ,
“batch_output”: ,
“optimization”: {
“priority”: “PRIORITY_DEFAULT”,
“cuda”: {
“graphs”: false,
“busy_wait_events”: false,
“graph_spec”: ,
“output_copy_stream”: true
“input_pinned_memory”: {
“enable”: true
“output_pinned_memory”: {
“enable”: true
“gather_kernel_buffer_threshold”: 0,
“eager_batching”: false
“sequence_batching”: {
“oldest”: {
“max_candidate_sequences”: 1,
“preferred_batch_size”: [
1
“max_queue_delay_microseconds”: 1000
“max_sequence_idle_microseconds”: 60000000,
“control_input”: [
“name”: “START”,
“control”: [
“kind”: “CONTROL_SEQUENCE_START”,
“int32_false_true”: [
0,
1
“fp32_false_true”: ,
“bool_false_true”: ,
“data_type”: “TYPE_INVALID”
“name”: “READY”,
“control”: [
“kind”: “CONTROL_SEQUENCE_READY”,
0,
1
“name”: “END”,
“control”: [
“kind”: “CONTROL_SEQUENCE_END”,
0,
1
“name”: “CORRID”,
“control”: [
“kind”: “CONTROL_SEQUENCE_CORRID”,
“int32_false_true”: ,
“data_type”: “TYPE_UINT64”
“state”:
“instance_group”: [
“name”: “citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming_0”,
“kind”: “KIND_CPU”,
“count”: 1,
“gpus”: ,
“secondary_devices”: ,
“profile”: ,
“passive”: false,
“host_policy”: “”
“default_model_filename”: “”,
“cc_model_filenames”: {},
“metric_tags”: {},
“parameters”: {
“use_vad”: {
“string_value”: “True”
“lm_weight”: {
“string_value”: “0.2”
“blank_token”: {
“string_value”: “#”
“vocab_file”: {
“string_value”: “/data/models/citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming/1/riva_decoder_vocabulary.txt”
“ms_per_timestep”: {
“string_value”: “80”
“streaming”: {
“use_subword”: {
“beam_size”: {
“string_value”: “16”
“right_padding_size”: {
“string_value”: “1.92”
“beam_size_token”: {
“sil_token”: {
“string_value”: “▁”
“beam_threshold”: {
“string_value”: “20.0”
“tokenizer_model”: {
“string_value”: “/data/models/citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming/1/50b43e991a5a4d26afab00bc85888757_tokenizer.model”
“language_model_file”: {
“string_value”: “/data/models/citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming/1/jarvis_asr_train_datasets_noSpgi_noLS_gt_3gram.binary”
“max_execution_batch_size”: {
“string_value”: “1024”
“forerunner_use_lm”: {
“string_value”: “true”
“forerunner_beam_size_token”: {
“string_value”: “8”
“forerunner_beam_threshold”: {
“string_value”: “10.0”
“asr_model_delay”: {
“string_value”: “-1”
“decoder_num_worker_threads”: {
“word_insertion_score”: {
“left_padding_size”: {
“decoder_type”: {
“string_value”: “flashlight”
“compute_timestamps”: {
“forerunner_beam_size”: {
“string_value”: “8”
“max_supported_transcripts”: {
“string_value”: “1”
“chunk_size”: {
“string_value”: “0.16”
“lexicon_file”: {
“string_value”: “/data/models/citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming/1/lexicon.txt”
“smearing_mode”: {
“string_value”: “max”
“model_warmup”: ,
“model_transaction_policy”: {
“decoupled”: false
I0602 03:31:30.493504 12 ctc-decoder-library.cc:23] TRITONBACKEND_ModelInstanceInitialize: citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming_0 (device 0)
I0602 03:31:30.580701 12 model_repository_manager.cc:994] loading: citrinet-256-en-US-streaming-voice-activity-detector-ctc-streaming:1
I0602 03:31:30.681082 12 model_repository_manager.cc:994] loading: riva-trt-citrinet-256:1
Waiting for Riva server to load all models…retrying in 10 seconds
I0602 03:31:31.885521 12 model_repository_manager.cc:1149] successfully loaded ‘citrinet-256-en-US-streaming-ctc-decoder-cpu-streaming’ version 1
I0602 03:31:31.886102 12 feature-extractor.cc:407] TRITONBACKEND_ModelInitialize: citrinet-256-en-US-streaming-feature-extractor-streaming (version 1)
W:parameter_parser.cc:120: Parameter is_dither_seed_random could not be set from parameters
W:parameter_parser.cc:120: Parameter max_batch_size could not be set from parameters
W:parameter_parser.cc:120: Parameter max_sequence_idle_microseconds could not be set from parameters
W:parameter_parser.cc:120: Parameter preemph_coeff could not be set from parameters
I0602 03:31:35.116544 12 backend_model.cc:255] model configuration:
“name”: “citrinet-256-en-US-streaming-feature-extractor-streaming”,
“platform”: “”,
“backend”: “riva_asr_features”,
“version_policy”: {
“latest”: {
“num_versions”: 1
“input”: [
“name”: “AUDIO_SIGNAL”,
“dims”: [
-1
“optional”: false
“name”: “SAMPLE_RATE”,
“dims”: [
1
“optional”: false
“output”: [
“name”: “AUDIO_FEATURES”,
“dims”: [
80,
-1
“name”: “AUDIO_PROCESSED”,
“dims”: [
1
“batch_input”: ,
“batch_output”: ,
“optimization”: {
“cuda”: {
“graphs”: false,
“graph_spec”: ,
“enable”: true
“enable”: true
“oldest”: {
1
“control_input”: [
“name”: “START”,
“control”: [
0,
1
“name”: “READY”,
“control”: [
0,
1
“name”: “END”,
“control”: [
0,
1
“name”: “CORRID”,
“control”: [
“state”:
“instance_group”: [
“name”: “citrinet-256-en-US-streaming-feature-extractor-streaming_0”,
“kind”: “KIND_GPU”,
“count”: 1,
“gpus”: [
0
“profile”: ,
“passive”: false,
“host_policy”: “”
“metric_tags”: {},
“parameters”: {
“use_utterance_norm_params”: {
“string_value”: “False”
“precalc_norm_time_steps”: {
“string_value”: “0”
“dither”: {
“string_value”: “1e-05”
“precalc_norm_params”: {
“norm_per_feature”: {
“mean”: {
“string_value”: “-11.4412, -9.9334, -9.1292, -9.0365, -9.2804, -9.5643, -9.7342, -9.6925, -9.6333, -9.2808, -9.1887, -9.1422, -9.1397, -9.2028, -9.2749, -9.4776, -9.9185, -10.1557, -10.3800, -10.5067, -10.3190, -10.4728, -10.5529, -10.6402, -10.6440, -10.5113, -10.7395, -10.7870, -10.6074, -10.5033, -10.8278, -10.6384, -10.8481, -10.6875, -10.5454, -10.4747, -10.5165, -10.4930, -10.3413, -10.3472, -10.3735, -10.6830, -10.8813, -10.6338, -10.3856, -10.7727, -10.8957, -10.8068, -10.7373, -10.6108, -10.3405, -10.2889, -10.3922, -10.4946, -10.3367, -10.4164, -10.9949, -10.7196, -10.3971, -10.1734, -9.9257, -9.6557, -9.1761, -9.6653, -9.7876, -9.7230, -9.7792, -9.7056, -9.2702, -9.4650, -9.2755, -9.1369, -9.1174, -8.9197, -8.5394, -8.2614, -8.1353, -8.1422, -8.3430, -8.6655”
“stddev”: {
“string_value”: “2.2668, 3.1642, 3.7079, 3.7642, 3.5349, 3.5901, 3.7640, 3.8424, 4.0145, 4.1475, 4.0457, 3.9048, 3.7709, 3.6117, 3.3188, 3.1489, 3.0615, 3.0362, 2.9929, 3.0500, 3.0341, 3.0484, 3.0103, 2.9474, 2.9128, 2.8669, 2.8332, 2.9411, 3.0378, 3.0712, 3.0190, 2.9992, 3.0124, 3.0024, 3.0275, 3.0870, 3.0656, 3.0142, 3.0493, 3.1373, 3.1135, 3.0675, 2.8828, 2.7018, 2.6296, 2.8826, 2.9325, 2.9288, 2.9271, 2.9890, 3.0137, 2.9855, 3.0839, 2.9319, 2.3512, 2.3795, 2.6191, 2.7555, 2.9326, 2.9931, 3.1543, 3.0855, 2.6820, 3.0566, 3.1272, 3.1663, 3.1836, 3.0018, 2.9089, 3.1727, 3.1626, 3.1086, 2.9804, 3.1107, 3.2998, 3.3697, 3.3716, 3.2487, 3.1597, 3.1181”
“chunk_size”: {
“string_value”: “1”
“sample_rate”: {
“string_value”: “16000”
“window_stride”: {
“string_value”: “0.01”
“window_size”: {
“string_value”: “0.025”
“num_features”: {
“streaming”: {
“transpose”: {
“stddev_floor”: {
“gain”: {
“string_value”: “1.0”
“model_warmup”: ,
“decoupled”: false
I0602 03:31:35.118372 12 vad_library.cc:19] TRITONBACKEND_ModelInitialize: citrinet-256-en-US-streaming-voice-activity-detector-ctc-streaming (version 1)
W:parameter_parser.cc:120: Parameter max_execution_batch_size could not be set from parameters
I0602 03:31:35.119653 12 backend_model.cc:255] model configuration:
“name”: “citrinet-256-en-US-streaming-voice-activity-detector-ctc-streaming”,
“platform”: “”,
“backend”: “riva_asr_vad”,
“version_policy”: {
“latest”: {
“num_versions”: 1
“input”: [
“dims”: [
-1,
1025
“optional”: false
“output”: [
“dims”: [
-1,
2
“batch_input”: ,
“batch_output”: ,
“optimization”: {
“cuda”: {
“graphs”: false,
“graph_spec”: ,
“enable”: true
“enable”: true
“control_input”: [
“name”: “START”,
“control”: [
0,
1
“name”: “READY”,
“control”: [
0,
1
“state”:
“instance_group”: [
“name”: “citrinet-256-en-US-streaming-voice-activity-detector-ctc-streaming_0”,
“kind”: “KIND_CPU”,
“count”: 1,
“gpus”: ,
“profile”: ,
“passive”: false,
“host_policy”: “”
“metric_tags”: {},
“parameters”: {
“residue_blanks_at_end”: {
“string_value”: “0”
“vad_start_history”: {
“string_value”: “300”
“vad_stop_history”: {
“string_value”: “800”
“chunk_size”: {
“vad_start_th”: {
“vad_stop_th”: {
“string_value”: “0.98”
“vad_type”: {
“string_value”: “ctc-vad”
“vocab_file”: {
“string_value”: “/data/models/citrinet-256-en-US-streaming-voice-activity-detector-ctc-streaming/1/riva_decoder_vocabulary.txt”
“residue_blanks_at_start”: {
“string_value”: “-2”
“streaming”: {
“use_subword”: {
“model_warmup”: ,
“decoupled”: false
I0602 03:31:35.119695 12 feature-extractor.cc:409] TRITONBACKEND_ModelInstanceInitialize: citrinet-256-en-US-streaming-feature-extractor-streaming_0 (device 0)
Health ready check failed.
Check Riva logs with: docker logs riva-speech
nvidia@nvidia-orin-desktop:~/exp/riva_quickstart_arm64_v2.0.0$ I0602 03:37:23.247325 12 vad_library.cc:22] TRITONBACKEND_ModelInstanceInitialize: citrinet-256-en-US-streaming-voice-activity-detector-ctc-streaming_0 (device 0)
E0602 03:37:23.247325 12 model_repository_manager.cc:1152] failed to load ‘riva-trt-citrinet-256’ version 1: Not found: unable to load shared library: /lib/aarch64-linux-gnu/libm.so.6: version `GLIBC_2.29’ not found (required by /usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so)
I0602 03:37:23.247730 12 model_repository_manager.cc:1149] successfully loaded ‘citrinet-256-en-US-streaming-feature-extractor-streaming’ version 1
I0602 03:37:23.248243 12 model_repository_manager.cc:1149] successfully loaded ‘citrinet-256-en-US-streaming-voice-activity-detector-ctc-streaming’ version 1
E0602 03:37:23.248288 12 model_repository_manager.cc:1332] Invalid argument: ensemble ‘citrinet-256-en-US-streaming’ depends on ‘riva-trt-citrinet-256’ which has no loaded version
I0602 03:37:23.248356 12 server.cc:522]
| Repository Agent | Path |
As the result , libm.so.6 need version GLIBC_2.29… but ubuntu 18.04 GLIBC version is 2.27…
