Riva Speech - NGC Docker pull error : Authorization Required
I am having difficulty installing the Riva speech skills container on my jetson xavier nx (ubuntu 20.4). I have downloaded riva_quickstart_v2.14
I have logged into ngc and created my personal key and can see the riva speech skills container.
Installed docker-ce
Installed gnc and successfully run
ngc config set
providing $oauthtoken and ngc key.
I have successfully executed
docker login nvcr.io
providing username: $oauthtoken, and my ngc key
Authenticating with existing credentials...
WARNING! Your password will be stored unencrypted in /home/coda/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
I have followed the instructions to download "nvidia/riva/riva_quickstart:2.14.0”
When I execute
bash riva_init.sh config.sh
I get the following error
$ bash riva_init.sh config.sh
Logging into NGC docker registry if necessary...
Pulling required docker images if necessary...
Note: This may take some time, depending on the speed of your Internet connection.
> Pulling Riva Speech Server images.
> Pulling nvcr.io/nvidia/riva/riva-speech:2.14.0. This may take some time...
> Attempt 1 out of 3 failed
> Trying again...
> Attempt 2 out of 3 failed
> Trying again...
> Attempt 3 out of 3 failed
Error occurred pulling 'nvcr.io/nvidia/riva/riva-speech:2.14.0'.
Error response from daemon: Head "https://nvcr.io/v2/nvidia/riva/riva-speech/manifests/2.14.0": unauthorized: <html>
<head><title>401 Authorization Required</title></head>
<body>
<center><h1>401 Authorization Required</h1></center>
<hr><center>nginx/1.22.1</center>
</body>
</html>
Exiting.
I also tried running this from my ubuntu 18.4 AMD64 linux system but get the same response.
To simplify things, I also tried executing the docker command directly but got the same outcome.
 docker pull -q nvcr.io/nvidia/riva/riva-speech:2.14.0
 <body>
 </body>
 </html>
Please can someone help?
Exactly the same problem here, trying to get this working on my new Jetson Orin AGX.
  • Created my NGC account & key
  • Installted NGC CLI and executed:
ngc config set
entering API key and hitting for the defaults for the rest.
Enter API key. Choices: [<VALID_APIKEY>, ‘no-apikey’]: nvapi-***
Enter CLI output format type [ascii]. Choices: [‘ascii’, ‘csv’, ‘json’]:
Enter org [re1drmm60mmg]. Choices: [‘re1drmm60mmg’]:
Enter team [no-team]. Choices: [‘no-team’]:
Enter ace [no-ace]. Choices: [‘no-ace’]:
Validating configuration…
Successfully validated configuration.
Saving configuration…
Successfully saved NGC configuration to /home/colin/.ngc/config
logged in docker with user $oauthtoken and API key as password:
Username: $oauthtoken
Password:
WARNING! Your password will be stored unencrypted in /home/colin/.docker/config.json.
docker login | Docker Docs
Login Succeeded
And finally trying to init Riva it fails at authenticating with docker :
bash riva_init.sh
Logging into NGC docker registry if necessary…
Pulling required docker images if necessary…
Pulling nvcr.io/nvidia/riva/riva-speech:2.14.0-l4t-aarch64. This may take some time…
Trying again…
Trying again…
Error occurred pulling ‘nvcr.io/nvidia/riva/riva-speech:2.14.0-l4t-aarch64’.
Error response from daemon: Head “https://nvcr.io/v2/nvidia/riva/riva-speech/manifests/2.14.0-l4t-aarch64”: unauthorized: authentication required
Exiting.
Note that I can successfully pull other packages, for example pytorch from nvcr.io/nvidia/ …
What is going on?? I am missing permissions or subscriptions or something else?
Same here.
Did all the authentication.
sudo bash riva_init.sh
Does even check for a valid API key, so thats good. But it fails during download.
Please enter API key for ngc.nvidia.com:
  > Pulling nvcr.io/nvidia/riva/riva-speech:2.14.0-l4t-aarch64. This may take some time...
  > Trying again...
  > Trying again...
Error occurred pulling 'nvcr.io/nvidia/riva/riva-speech:2.14.0-l4t-aarch64'.
Error response from daemon: Head "https://nvcr.io/v2/nvidia/riva/riva-speech/manifests/2.14.0-l4t-aarch64": unauthorized: authentication required
Exiting.
same question!
Is it an official problem with nvidia?
The interface and method of generating NGC keys are different from the previous ones.
Still not working. This really looks like a server-side authentication problem and not a user problem …
Anyone at nvidia looking into this?
REJOICE!
The NGC Setup has been updated and there is now a Generate Personal Key option AND the Generate API Key now generate a valid key solving the above unauthorized: authentication required error.
