when ever I run riva_init.sh from riva quickstart 2.6.0 I get the following error
Logging into NGC docker registry if necessary...
NGC API Key is invalid. Please check and try again.
I have tried everything suggested on this post:
including generating a new key, setting things up with ngc config set docker login nvcr(dot)io works fine, no NGC_API_KEY variable set, and things don’t change when i do set it.
I’m trying to run it locally on a Turing GPU so I’m pretty sure I meet the minimum requirements to do so, I just have no idea why it doesn’t like my API key
any help would be appreciated
HI @proniss1
Thanks for your interest in Riva
Apologies you are facing issues
can you please run
cat $HOME/.ngc/config
and check whether the API key matches the one generated from portal
NOTE: never share this output/information as it contains your API key (sensitive information)
Can you also try running riva_init.sh using sudo
sudo bash riva_init.sh
and share the complete log output
Can you also try setting Enivornment variable NGC_CLI_API_KEY with the apikey from portal and try
did produce the correct API key
seems to have resolved the issue, thanks, I cant believe I didn’t think of that :S
