I’m running Ubuntu 16.04.1 LTS x64 (4.8.0-36-generic #36~16.04.1-Ubuntu SMP) and am unable to suspend to RAM with driver 375.26-0ubuntu1. Two GPUs, Nvidia GTX 670 (not in SLI).
I am triggering suspend to RAM via pm-suspend, systemctl suspend, or selecting suspend option in Unity before logging in. Regardless of how I do it, my screens always go blank except for a single text cursor that doesn’t blink. No input works any more, but all power is still on, and CPU appears to be at 100% (based on wattage consumption). Nothing shows up in syslog (see below). Only thing I can do in this state is reset / power cycle. This is 100% reproducible, but I don’t know how to meaningfully debug this.
I uninstalled 375.26-0ubuntu1 and installed 367.57-0ubuntu0.16.04.1, and the suspend problems go away. Without any nvidia drivers installed and using the default Nouveau drivers, suspend also works. So I suspect this problem is specific to 375.
Unfortunately for me, I need CUDA 8.0, and the CUDA installer uninstalls 367 and installs 375. Workarounds or other suggestions much appreciated.
Here are some comparisons of /var/log/syslog on 367 and 375 when I issue the suspend command. The 375 log looks exactly like the 367 at the beginning, gets hung at some point, and the next entry is the restart of the system after I reset.
On 375: suspend at 16:50, reset
Feb 12 07:16:50 home NetworkManager[1162]: <info> [1486912610.2089] manager: sleep requested (sleeping: no enabled: yes)
Feb 12 07:16:50 home NetworkManager[1162]: <info> [1486912610.2089] manager: sleeping...
Feb 12 07:16:50 home NetworkManager[1162]: <info> [1486912610.2090] manager: NetworkManager state is now ASLEEP
Feb 12 07:16:50 home whoopsie[1141]: [07:16:50] offline
Feb 12 07:16:50 home systemd[1]: Reached target Sleep.
Feb 12 07:16:50 home systemd[1]: Starting Suspend...
Feb 12 07:16:50 home systemd-sleep[6522]: Failed to connect to non-global ctrl_ifname: (nil) error: No such file or directory
Feb 12 07:16:50 home systemd-sleep[6523]: /lib/systemd/system-sleep/wpasupplicant failed with error code 255.
Feb 12 07:16:50 home systemd-sleep[6522]: Suspending system.
Feb 12 07:19:19 home rsyslogd: [origin software="rsyslogd" swVersion="8.16.0" x-pid="1114" x-info="http://www.rsyslog.com"] start
On 367: suspend at 53:38, resume at 53:49
Feb 12 07:53:38 home NetworkManager[1184]: <info> [1486914818.0894] manager: sleep requested (sleeping: no enabled: yes)
Feb 12 07:53:38 home NetworkManager[1184]: <info> [1486914818.0895] manager: sleeping...
Feb 12 07:53:38 home NetworkManager[1184]: <info> [1486914818.0895] manager: NetworkManager state is now ASLEEP
Feb 12 07:53:38 home whoopsie[1107]: [07:53:38] offline
Feb 12 07:53:38 home systemd[1]: Reached target Sleep.
Feb 12 07:53:38 home systemd[1]: Starting Suspend...
Feb 12 07:53:38 home systemd-sleep[3689]: Failed to connect to non-global ctrl_ifname: (nil) error: No such file or directory
Feb 12 07:53:38 home systemd-sleep[3690]: /lib/systemd/system-sleep/wpasupplicant failed with error code 255.
Feb 12 07:53:38 home systemd-sleep[3689]: Suspending system...
Feb 12 07:53:38 home kernel: [ 303.626951] PM: Syncing filesystems ... done.
Feb 12 07:53:38 home kernel: [ 303.652066] PM: Preparing system for sleep (mem)
Feb 12 07:53:49 home kernel: [ 304.053097] Freezing user space processes ... (elapsed 0.001 seconds) done.
Feb 12 07:53:49 home kernel: [ 304.054513] Double checking all user space processes after OOM killer disable... (elapsed 0.000 seconds)
Feb 12 07:53:49 home kernel: [ 304.054552] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Feb 12 07:53:49 home kernel: [ 304.055687] PM: Suspending system (mem)
Feb 12 07:53:49 home kernel: [ 304.055713] Suspending console(s) (use no_console_suspend to debug)
Feb 12 07:53:49 home kernel: [ 304.055917] sd 2:0:0:0: [sdc] Synchronizing SCSI cache
Feb 12 07:53:49 home kernel: [ 304.055929] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
Feb 12 07:53:49 home kernel: [ 304.055930] sd 0:0:0:0: [sda] Synchronizing SCSI cache
Feb 12 07:53:49 home kernel: [ 304.056005] sd 0:0:0:0: [sda] Stopping disk
Feb 12 07:53:49 home kernel: [ 304.056040] sd 1:0:0:0: [sdb] Stopping disk
Feb 12 07:53:49 home kernel: [ 304.056060] sd 2:0:0:0: [sdc] Stopping disk
Feb 12 07:53:49 home kernel: [ 304.056279] serial 00:02: disabled
Feb 12 07:53:49 home kernel: [ 304.056437] parport_pc 00:01: disabled
Feb 12 07:53:49 home kernel: [ 304.057333] e1000e: EEE TX LPI TIMER: 00000011
Feb 12 07:53:49 home kernel: [ 304.800028] PM: suspend of devices complete after 743.747 msecs
Feb 12 07:53:49 home kernel: [ 304.800445] PM: late suspend of devices complete after 0.415 msecs
Feb 12 07:53:49 home kernel: [ 304.800873] xhci_hcd 0000:07:00.0: System wakeup enabled by ACPI
Feb 12 07:53:49 home kernel: [ 304.800965] e1000e 0000:00:1f.6: System wakeup enabled by ACPI
Feb 12 07:53:49 home kernel: [ 304.801160] xhci_hcd 0000:00:14.0: System wakeup enabled by ACPI
Feb 12 07:53:49 home kernel: [ 304.838257] PM: noirq suspend of devices complete after 37.785 msecs
Feb 12 07:53:49 home kernel: [ 304.839088] ACPI: Preparing to enter system sleep state S3
Feb 12 07:53:49 home kernel: [ 304.840563] PM: Saving platform NVS memory
Feb 12 07:53:49 home kernel: [ 304.840652] Disabling non-boot CPUs ...
Feb 12 07:53:49 home kernel: [ 304.841151] Broke affinity for irq 124
Feb 12 07:53:49 home kernel: [ 304.841163] Broke affinity for irq 128
Feb 12 07:53:49 home kernel: [ 304.841167] Broke affinity for irq 129
Feb 12 07:53:49 home kernel: [ 304.841171] Broke affinity for irq 133
Feb 12 07:53:49 home kernel: [ 304.842245] smpboot: CPU 1 is now offline
Feb 12 07:53:49 home kernel: [ 304.859243] Broke affinity for irq 19
Feb 12 07:53:49 home kernel: [ 304.859252] Broke affinity for irq 123
Feb 12 07:53:49 home kernel: [ 304.859256] Broke affinity for irq 124
Feb 12 07:53:49 home kernel: [ 304.859260] Broke affinity for irq 125
Feb 12 07:53:49 home kernel: [ 304.859263] Broke affinity for irq 126
Feb 12 07:53:49 home kernel: [ 304.859269] Broke affinity for irq 128
Feb 12 07:53:49 home kernel: [ 304.859273] Broke affinity for irq 129
Feb 12 07:53:49 home kernel: [ 304.859277] Broke affinity for irq 133
Feb 12 07:53:49 home kernel: [ 304.859281] Broke affinity for irq 134
Feb 12 07:53:49 home kernel: [ 304.860340] smpboot: CPU 2 is now offline
Feb 12 07:53:49 home kernel: [ 304.882993] Broke affinity for irq 1
Feb 12 07:53:49 home kernel: [ 304.882997] Broke affinity for irq 5
Feb 12 07:53:49 home kernel: [ 304.883001] Broke affinity for irq 8
Feb 12 07:53:49 home kernel: [ 304.883005] Broke affinity for irq 9
Feb 12 07:53:49 home kernel: [ 304.883009] Broke affinity for irq 12
Feb 12 07:53:49 home kernel: [ 304.883014] Broke affinity for irq 19
Feb 12 07:53:49 home kernel: [ 304.883023] Broke affinity for irq 123
Feb 12 07:53:49 home kernel: [ 304.883027] Broke affinity for irq 124
Feb 12 07:53:49 home kernel: [ 304.883031] Broke affinity for irq 125
Feb 12 07:53:49 home kernel: [ 304.883035] Broke affinity for irq 126
Feb 12 07:53:49 home kernel: [ 304.883038] Broke affinity for irq 127
Feb 12 07:53:49 home kernel: [ 304.883042] Broke affinity for irq 128
Feb 12 07:53:49 home kernel: [ 304.883045] Broke affinity for irq 129
Feb 12 07:53:49 home kernel: [ 304.883050] Broke affinity for irq 133
Feb 12 07:53:49 home kernel: [ 304.883054] Broke affinity for irq 134
Feb 12 07:53:49 home kernel: [ 304.884115] smpboot: CPU 3 is now offline
Feb 12 07:53:49 home kernel: [ 304.901305] ACPI: Low-level resume complete
Feb 12 07:53:49 home kernel: [ 304.901391] PM: Restoring platform NVS memory
Feb 12 07:53:49 home kernel: [ 304.902107] Enabling non-boot CPUs ...
Feb 12 07:53:49 home kernel: [ 304.925375] x86: Booting SMP configuration:
Feb 12 07:53:49 home kernel: [ 304.925376] smpboot: Booting Node 0 Processor 1 APIC 0x2
Feb 12 07:53:49 home kernel: [ 304.927812] cache: parent cpu1 should not be sleeping
Feb 12 07:53:49 home kernel: [ 304.927917] CPU1 is up
Feb 12 07:53:49 home kernel: [ 304.981680] smpboot: Booting Node 0 Processor 2 APIC 0x4
Feb 12 07:53:49 home kernel: [ 304.985164] cache: parent cpu2 should not be sleeping
Feb 12 07:53:49 home kernel: [ 304.985722] CPU2 is up
Feb 12 07:53:49 home kernel: [ 305.025775] smpboot: Booting Node 0 Processor 3 APIC 0x6
Feb 12 07:53:49 home kernel: [ 305.029269] cache: parent cpu3 should not be sleeping
Feb 12 07:53:49 home kernel: [ 305.029870] CPU3 is up
Feb 12 07:53:49 home kernel: [ 305.038806] ACPI: Waking up from system sleep state S3
Feb 12 07:53:49 home kernel: [ 305.065420] xhci_hcd 0000:00:14.0: System wakeup disabled by ACPI
Feb 12 07:53:49 home kernel: [ 305.081548] xhci_hcd 0000:07:00.0: System wakeup disabled by ACPI
Feb 12 07:53:49 home kernel: [ 305.081585] PM: noirq resume of devices complete after 37.290 msecs
Feb 12 07:53:49 home kernel: [ 305.082703] PM: early resume of devices complete after 1.054 msecs
Feb 12 07:53:49 home kernel: [ 305.082972] usb usb1: root hub lost power or was reset
Feb 12 07:53:49 home kernel: [ 305.082975] usb usb2: root hub lost power or was reset
Feb 12 07:53:49 home kernel: [ 305.083186] e1000e 0000:00:1f.6: System wakeup disabled by ACPI
Feb 12 07:53:49 home kernel: [ 305.085439] parport_pc 00:01: activated
Feb 12 07:53:49 home kernel: [ 305.087007] serial 00:02: activated
Feb 12 07:53:49 home kernel: [ 305.087015] rtc_cmos 00:05: System wakeup disabled by ACPI
Feb 12 07:53:49 home kernel: [ 305.087403] usb usb3: root hub lost power or was reset
Feb 12 07:53:49 home kernel: [ 305.087405] usb usb4: root hub lost power or was reset
Feb 12 07:53:49 home kernel: [ 305.158275] sd 1:0:0:0: [sdb] Starting disk
Feb 12 07:53:49 home kernel: [ 305.158275] sd 0:0:0:0: [sda] Starting disk
Feb 12 07:53:49 home kernel: [ 305.158284] sd 2:0:0:0: [sdc] Starting disk
Feb 12 07:53:49 home kernel: [ 305.431047] usb 1-14: reset high-speed USB device number 2 using xhci_hcd
Feb 12 07:53:49 home kernel: [ 305.532009] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Feb 12 07:53:49 home kernel: [ 305.532040] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Feb 12 07:53:49 home kernel: [ 305.532053] ata5: SATA link down (SStatus 4 SControl 300)
Feb 12 07:53:49 home kernel: [ 305.532066] ata6: SATA link down (SStatus 4 SControl 300)
Feb 12 07:53:49 home kernel: [ 305.542027] ata1.00: supports DRM functions and may not be fully accessible
Feb 12 07:53:49 home kernel: [ 305.556548] ata4.00: configured for UDMA/133
Feb 12 07:53:49 home kernel: [ 305.563371] ata1.00: disabling queued TRIM support
Feb 12 07:53:49 home kernel: [ 305.594373] ata1.00: supports DRM functions and may not be fully accessible
Feb 12 07:53:49 home kernel: [ 305.619325] ata1.00: disabling queued TRIM support
Feb 12 07:53:49 home kernel: [ 305.625961] ata1.00: configured for UDMA/133
Feb 12 07:53:49 home kernel: [ 305.751158] firewire_core 0000:06:00.0: rediscovered device fw0
Feb 12 07:53:49 home kernel: [ 306.110228] usb 1-14.1: reset full-speed USB device number 3 using xhci_hcd
Feb 12 07:53:49 home kernel: [ 306.365858] usb 1-14.2: reset full-speed USB device number 8 using xhci_hcd
Feb 12 07:53:49 home kernel: [ 306.695998] usb 1-14.1.2: reset full-speed USB device number 5 using xhci_hcd
Feb 12 07:53:49 home kernel: [ 307.131629] PM: resume of devices complete after 2047.791 msecs
Feb 12 07:53:49 home kernel: [ 307.131895] PM: Finishing wakeup.
Feb 12 07:53:49 home kernel: [ 307.131896] Restarting tasks ...
Feb 12 07:53:49 home kernel: [ 307.132056] e1000e: enp0s31f6 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
Feb 12 07:53:49 home kernel: [ 307.132058] e1000e 0000:00:1f.6 enp0s31f6: 10/100 speed: disabling TSO
Feb 12 07:53:49 home kernel: [ 307.132227] pci_bus 0000:05: Allocating resources
Feb 12 07:53:49 home kernel: [ 307.132238] pci 0000:04:00.0: bridge window [io 0x1000-0x0fff] to [bus 05] add_size 1000
Feb 12 07:53:49 home kernel: [ 307.132239] pci 0000:04:00.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05] add_size 200000 add_align 100000
Feb 12 07:53:49 home kernel: [ 307.132240] pci 0000:04:00.0: bridge window [mem 0x00100000-0x000fffff] to [bus 05] add_size 200000 add_align 100000
Feb 12 07:53:49 home kernel: [ 307.132241] pci 0000:04:00.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
Feb 12 07:53:49 home kernel: [ 307.132241] pci 0000:04:00.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
Feb 12 07:53:49 home kernel: [ 307.132242] pci 0000:04:00.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
Feb 12 07:53:49 home kernel: [ 307.132243] pci 0000:04:00.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
Feb 12 07:53:49 home kernel: [ 307.132243] pci 0000:04:00.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
Feb 12 07:53:49 home kernel: [ 307.132244] pci 0000:04:00.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
Feb 12 07:53:49 home kernel: [ 307.132245] pci 0000:04:00.0: BAR 14: no space for [mem size 0x00200000]
Feb 12 07:53:49 home kernel: [ 307.132245] pci 0000:04:00.0: BAR 14: failed to assign [mem size 0x00200000]
Feb 12 07:53:49 home kernel: [ 307.132246] pci 0000:04:00.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
Feb 12 07:53:49 home kernel: [ 307.132246] pci 0000:04:00.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
Feb 12 07:53:49 home kernel: [ 307.132247] pci 0000:04:00.0: BAR 13: no space for [io size 0x1000]
Feb 12 07:53:49 home kernel: [ 307.132247] pci 0000:04:00.0: BAR 13: failed to assign [io size 0x1000]
Feb 12 07:53:49 home kernel: [ 307.132248] pci 0000:04:00.0: BAR 14: no space for [mem size 0x00200000]
Feb 12 07:53:49 home kernel: [ 307.132249] pci 0000:04:00.0: BAR 14: failed to assign [mem size 0x00200000]
Feb 12 07:53:49 home kernel: [ 307.132249] pci 0000:04:00.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
Feb 12 07:53:49 home kernel: [ 307.132250] pci 0000:04:00.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
Feb 12 07:53:49 home kernel: [ 307.132250] pci 0000:04:00.0: BAR 13: no space for [io size 0x1000]
Feb 12 07:53:49 home kernel: [ 307.132251] pci 0000:04:00.0: BAR 13: failed to assign [io size 0x1000]
Feb 12 07:53:49 home kernel: [ 307.132251] pci 0000:04:00.0: PCI bridge to [bus 05]
Feb 12 07:53:49 home systemd[1983]: Time has been changed
Feb 12 07:53:49 home systemd[1]: Time has been changed
Feb 12 07:53:49 home systemd[1]: snapd.refresh.timer: Adding 4h 16min 45.744513s random time.
Feb 12 07:53:49 home systemd[1]: snapd.refresh.timer: Adding 4h 40min 32.511656s random time.
Feb 12 07:53:49 home systemd[1]: apt-daily.timer: Adding 4h 57min 811.661ms random time.
Feb 12 07:53:49 home acpid: client 1303[0:0] has disconnected
Feb 12 07:53:49 home systemd-sleep[3689]: System resumed.
