I have GTX 1080ti on Ubuntu 16.04
Driver: 375.66
CUDA 8.0-61.1
libcuda 375.66
cuda-drivers 375.51-1
Problem:
After suspending PC cuda lib is not working anymore:
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 30
-> unknown error
Result = FAIL
WARNING (theano.sandbox.cuda): CUDA is installed, but device gpu is not available (error: Unable to get the number of gpus available: unknown error)
However at the same time nvidia-smi works absolutetly fine
cypreess@gtx:~/dev/NVIDIA_CUDA-8.0_Samples/bin/x86_64/linux/release$ nvidia-smi
Fri Jun 9 20:49:59 2017
| NVIDIA-SMI 375.66 Driver Version: 375.66 |
| 0 GeForce GTX 108... Off | 0000:01:00.0 On | N/A |
| 23% 37C P8 18W / 250W | 727MiB / 11169MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1261 G /usr/lib/xorg/Xorg 25MiB |
| 0 1463 G /usr/lib/xorg/Xorg 329MiB |
| 0 1801 G /usr/bin/gnome-shell 182MiB |
| 0 2526 G /proc/self/exe 27MiB |
| 0 5243 G ...el-token=682029E6D17C8080D4B5A7BE0DA20F10 130MiB |
I was trying to change mode using:
/usr/bin/nvidia-smi -pm ENABLED
/usr/bin/nvidia-smi -c EXCLUSIVE_PROCESS
without any luck.
Only PC restart fixes the problem.
nvidia-bug-report.log.gz (168 KB)
