Rootfs encryption with dm-crypt on Jetson Nano with eMMC variant
I am using the NVIDIA Jetson Linux 32.7.4 release on Seeed Studio Jetson Nano (reComputer J1010 Kit). I want to encrypt the roofs partition. Can I use dm-crypt with LUKS? I read on Nvidia forums that Trusty isn’t supported on Jetson Nano (using tegra210 software variant) and dm-crypt is used along with Trusty. Can somebody provide some information the above assumption holds true?
hello asau,
it’s not supported.
as you can see in the Disk Encryption chapter.
Applies to: Jetson Xavier NX series, Jetson AGX Xavier series, and Jetson TX2 series
Thank you very much @JerryChang for your answer.
So now I can see that both Trusty and LUKS are not supported for Jetson Nano? So is it possible can you please provide the below suggestions?
  1. The TEE implementation; TRUSTY is not supported. So what it the alternative here?
  2. What can be the other alternative for encryption on Jetson Nano? If I go for fscrypt with the file based encryption compared to block encryption earlier, will this work?
you should moving to Jetson TX2 series (or later) to enable disk encryption.
