ROS1 RTX LiDAR python example
Hi I’m having the same issue with incomplete scans as found in this thread:
I haven’t been able to find docs on how to use the RTXLidarScanBuffer with a ROS1 Publish Pointcloud node. I am using the OS13220hz1024res sensor config. Ideally I would like to know how to modify the rtx_lidar.py standalone example to use a buffer so the published cloud is always a complete 360 scan.
Hi @rbelshaw - If you have the same issue, that thread was resolved with the answer, didn’t that work for you?
Also, have you reviewed this doc? RTX Lidar Nodes — Omniverse IsaacSim latest documentation
