I would like to manage multiple ROScube (RQX-59G) devices that I currently own.
At the moment, I am considering using the “serial” field reported by the lshw command as a hardware-specific identifier. However, I would like to confirm whether this value is guaranteed to be unique across devices. Is it ensured that this serial value will not overlap with other ROScube units?
If there is any possibility of duplication, could you please advise on a reliable method to obtain a truly unique identifier for each device?
I would like to confirm whether the values obtained using the lshw command on a system equipped with an NVIDIA Jetson AGX Orin module are guaranteed to be unique across devices.
I would appreciate any clarification you can provide on this.
