zzy1@zzy1:~$ sudo cyclictest -t 5 -p 50 --n
WARN: cyclictest was not built with the numa option
/dev/cpu_dma_latency set to 0us
policy: fifo: loadavg: 0.82 1.17 1.10 1/648 3803
T: 0 ( 3797) P:50 I:1000 C: 8602 Min: 18092 Act: 24499 Avg: 30118 Max: 118496
T: 1 ( 3798) P:50 I:1500 C: 5734 Min: 19468 Act: 24675 Avg: 29667 Max: 111945
T: 2 ( 3799) P:50 I:2000 C: 4301 Min: 19594 Act: 23058 Avg: 30292 Max: 136324
T: 3 ( 3800) P:50 I:2500 C: 3440 Min: 19794 Act: 70646 Avg: 37450 Max: 136564
T: 4 ( 3801) P:50 I:3000 C: 2867 Min: 18364 Act: 22143 Avg: 34760 Max: 141682
zzy@zzy:~uname -a
Linux titr 5.10.120-rt70-tegra #1 SMP PREEMPT RT Tue Jan 30 09:42:17 CST 2024 aarch64 aarch64 aarch64 GNU/Linux
我在尝试 构建实时内核。在烧录后使用cyclctest查看,延时还是很高。
zzy@zzy:~/jetson/Linux_for_Tegra/rootfs/lib/modules$ ls
5.10.120-rt70-tegra 5.10.120-tegra
我的步骤
- 打开.p3668.conf.common 删除 console=ttyTCU0,
- ./kernel-5.10/scripts/rt-patch.sh apply-patches
- 在/kernel-5.10 make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
- sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j16
- 替换 Image 和 dts
- sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install
INSTALL_MOD_PATH=$HOME/jetson/Linux_for_Tegra/rootfs/ - cd $HOME/software/JetsonNX/Linux_for_Tegra/rootfs
tar --owner root --group root -cjf kernel_supplements.tbz2 lib/modules - 替换kernel_supplements.tbz2
- sudo ./apply_binaries.sh
- sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1
-c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_l4t_t194_qspi_p3668.xml”
–showlogs --network usb0 jetson-xavier-nx-devkit internal
