I have successfully flashed the real-time kernel using the method of compiling the kernel according to the official website manual.
And also attempted to use OTA methods, that is,
sudo apt install nvidia-l4t-rt-kernel nvidia-l4t-rt-kernel-headers nvidia-l4t-rt-kernel-oot-modules nvidia-l4t-display-rt-kernel
I have tried both methods and the final result is consistent:
uname-r
It’s all displayed
xxxx-rt-xxx
But I am using the Jetson Orin NX 16g version
sudo apt install rt-tests
Installed testing tools and used
sudo cyclictest -t 8 -D 1h --policy=fifo
Command, conduct testing.
From the test results, it can be seen that the real-time kernel is different from the regular kernel (or primary kernel?)? )The effect is exactly the same.
Does it not reflect real-time performance? What settings should I make?
note:
My Jetson seems to be started by UEFI, which is all the background of the problem I encountered. I have no idea where to start.
