anrui
December 3, 2021, 7:33am
1
HI nvidia,
I used the rtl8822ce WiFi module on the Jeston nano,
the Image is jetson-nx-jp46-sd-card-image
kernel log as follows file:
[ 6.665285] rtl88x2ce 0000:01:00.0: enabling device (0000 → 0003)
[ 6.692471] mc-err: (0) csr_afir: EMEM address decode error
[ 6.698203] mc-err: status = 0x2000000e; addr = 0x63d18000
[ 6.703933] mc-err: secure: no, access-type: read, SMMU fault: none
8822ce_err.txt (67.6 KB)
kayccc
December 3, 2021, 8:23am
2
anrui
December 6, 2021, 8:44am
4
Hi I’ve seen this post
I have two question:
As you say, I’ll revome the whole three line? or I’ll remove the prefixion(/delete-property/).
How does DTB take effect on boards, I try to move the dtb to /boot/, But it didn’t effect on the jeston-nano Development board.
anrui
December 6, 2021, 9:41am
6
yes, I used these shell script to flash the version
sudo ./flash.sh jetson-nano-qspi-sd.conf mmcblk0p1
Ok, then put modified dtb to kernel/dtb (make sure you know which file is in use).
And run command to flash DTB only.
sudo ./flash.sh -r -k DTB jetson-nano-qspi-sd.conf mmcblk0p1
anrui
December 7, 2021, 2:04am
8
Hi
1.I took out the DTB file which running on the board and compiled it into DTS, but I didn’t find SMMU configured about pcie, The generated DTS file is as follows;
kernel_tegra210-p3448-0000-p3449-0000-a02.dts (306.6 KB)
2.I think /delete-property/ means annotation the dts property, is as same as delete the three lines;
If “/delete-property/” is removed, it means the original iommus, iommu-map and iommu-map-mask shall appear.
These 3 lines were originally from hardware/nvidia/soc/t210/kernel-dts/tegra210-soc/tegra210-soc-base.dtsi.
Make sure you really do the correct work to your dts to let these 3 lines back.
anrui
December 7, 2021, 2:45am
10
hi
now I have modify the dts(tegra210-p3448-0000-p3449-0000-a02.dts),how can I compile the dts to dtb.
The file path is as follows:
anrui
December 7, 2021, 6:21am
12
I have modify the dtsi as you send but through the log, the error is the same as before.
this is the file of pcie dts
this is the flash log, uploading and flashing ok
nvida_flash_dtb_ok.txt (15.2 KB)
this is the rtl8822ce error dmesg log
rtc8822ce_dmesg.txt (63.2 KB)
What is your exact method to add these 3 lines back…???
These 3 lines all have their own field but not just some keyword style properties…
Open hardware/nvidia/soc/t210/kernel-dts/tegra210-soc/tegra210-soc-base.dtsi and search them under pcie and you will understand what I am talking about…
anrui
December 7, 2021, 7:31am
14
thank you! the Problem has been solved
system
Closed
December 29, 2021, 5:07am
16
