Nano kit uses RTL91191 EC. The datasheet is not available on internet. However, as it is indicated in the Nano’s design guide, Nano module includes the Ethernet Phy and ready for magnetic and connector, however my project requires 6 Ports. Can the Nano Ethernet connection (figure 9) be capacitor coupled to a 4-port BCM53134 switch. The BCM53134 is Low Power Digital to Analog Converter (LDAC) and designed for transformerless capacitor-coupling ?
Related topics
Topic | Replies | Views | Activity | |
Ethernet Phy for Jetson Nano | 4 | 1313 | October 18, 2021 | |
Custom carrier board Validated Ethernet Magnetics | 4 | 2214 | October 18, 2021 | |
Nano docs | 2 | 797 | October 18, 2021 | |
Enthernet Phy used for Jetson Nano and Jetson Xavier NX | 4 | 1627 | October 18, 2021 | |
How to use jetson nano‘s Ethernet | 18 | 1581 | October 18, 2021 | |
Jetson Nano Ethernet compliance test support | 5 | 852 | October 14, 2021 | |
Jetson Nano GbE port AC coupling to ethernet switch IC | 2 | 407 | October 8, 2022 | |
jetson nano ethernet expand | 5 | 1550 | October 15, 2021 | |
Redundant Ethernet port for Jetson Nano | 2 | 420 | October 15, 2021 | |
Jetson NANO based custom design of Ethernet switch | 2 | 888 | October 18, 2021 |
