Is it known which USB to Ethernet adapters, or what USB to Ethernet adapter chipsets work with the Nano?
If so, could someone point me to those items?
So far, my searching hasn’t returned much useful info and the adapter I do have, which employs the ASIX AX88179 chipset, does not seem to be fully working with the Nano. I can provide more info in my next post when I’m back in front of my development setup again.
No worries. I installed the 32.5 L4T system image, and since than the adapter I’m using with the chipset listed is now working as expected. I’m not sure if that’s due to a change in 32.5, or if there was something initially not working correctly with my setup.
Would you happen to know of any other USB to Ethernet chipsets that work well with the Nano?
Sorry no, the USB used for Ethernet requires loading of the NVIDIA XHCI firmware to enable the host port was implemented, so general ethernet dongle which supports LinuxK4.9/Ubuntu 18.04 should work.
