RTP Stream
Hardware Platform: Jetson nano
DeepStream Version: 6.0
JetPack Version: 4.6.1
How can I subscribe an RTP stream in deepstream config. I have added a source with RTSP and got this error:
No valid RTSP URL was provided
and I changed it to URI and got this error:
EERROR from src_elem: No URI handler implemented for “rtp”.
The URI:
uri=rtp://192.168.20.3:11024
Note: RTSP not RTP
Deepstream is based on Gstreamer. You can refer to the rtp support in Gstreamer..
rtp://192.168.20.3:11025
I tried uri and rtsp and it did not work.
Can you describe the method you used to build an RTP stream?
Please make sure that I want to use it as a source in the source group in my config file.
The video is streaming and I could see it through rtp://192.168.20.3:11025 using VLC media player.
Yes. Can you provide a method for building RTP streams? So we can try to reproduce the problem.
