RTSP Camera insted of Usb Camera
Hi.
Just bought a Nvidia Jetson nano and have started with the first course. I want to use a network camera insted of the usb or csi. Have succseded to get picture in vlc from my rtsp stream.
I have read a lot in this forum how to accomplish this but i don´t really understand.
I found in a post a link to gstCamera.cpp but i dont understand where i shall put it or how to call this skript i the example code in.
Can someone help understand how it all is put together or point me in right direction where to start.
/Niclas
You may run with uridecodebin. Please refer to
More examples are in gstreamer user guide:
Thanks. Starting to get somewhere. when I tried gst-launch-1.0 uridecodebin uri=rtsp://192.168.80.51/MOBILE/media.smp ! nvoverlaysink I got a streaming picture.
Have tried to replace the csi camera in JupyterLab and get a error that I don’t solve.
Can someone help to se what’s wrong?
Full reset of the camera
!echo ‘dlinano’ | sudo -S systemctl restart nvargus-daemon && printf ‘\n’
Check device number
!ls -ltrh /dev/video*
USB Camera (Logitech C270 webcam)
#from jetcam.usb_camera import USBCamera
camera = USBCamera(width=224, height=224, capture_device=0) # confirm the capture_device number
CSI Camera (Raspberry Pi Camera Module V2)
#from jetcam.csi_camera import CSICamera
import sys
import cv2
vcap = cv2.VideoCapture(“rtsp://192.168.80.51/MOBILE/media.smp”)
while(1):
ret, frame = vcap.read()
cv2.imshow(‘VIDEO’, frame)
cv2.waitKey(1)
camera = cv2.VideoCapture(gst)
camera = (width=224, height=224)
camera = CSICamera(width=224, height=224)
camera.running = True
print(“camera created”)
[sudo] password for dlinano:
crw-rw----+ 1 root video 81, 0 Mar 30 00:12 /dev/video0
Task
Next, define your project TASK and what CATEGORIES of data you will collect. You may optionally define space for multiple DATASETS with names of your choosing.
Uncomment/edit the associated lines for the classification task you’re building and execute the cell. This cell should only take a few seconds to execute.
import torchvision.transforms as transforms
from dataset import ImageClassificationDataset
TASK = ‘thumbs’
TASK = ‘emotions’
TASK = ‘fingers’
TASK = ‘diy’
CATEGORIES = [‘thumbs_up’, ‘thumbs_down’]
CATEGORIES = [‘none’, ‘happy’, ‘sad’, ‘angry’]
CATEGORIES = [‘1’, ‘2’, ‘3’, ‘4’, ‘5’]
CATEGORIES = [ ‘diy_1’, ‘diy_2’, ‘diy_3’]
DATASETS = [‘A’, ‘B’]
DATASETS = [‘A’, ‘B’, ‘C’]
TRANSFORMS = transforms.Compose([
transforms.ColorJitter(0.2, 0.2, 0.2, 0.2),
transforms.Resize((224, 224)),
transforms.ToTensor(),
transforms.Normalize([0.485, 0.456, 0.406], [0.229, 0.224, 0.225])
datasets = {}
for name in DATASETS:
datasets[name] = ImageClassificationDataset(TASK + ‘_’ + name, CATEGORIES, TRANSFORMS)
print(“{} task with {} categories defined”.format(TASK, CATEGORIES))
Data Collection
Execute the cell below to create the data collection tool widget. This cell should only take a few seconds to execute.
import ipywidgets
import traitlets
from IPython.display import display
from jetcam.utils import bgr8_to_jpeg
initialize active dataset
dataset = datasets[DATASETS[0]]
unobserve all callbacks from camera in case we are running this cell for second time
camera.unobserve_all()
create image preview
camera_widget = ipywidgets.Image()
traitlets.dlink((camera, ‘value’), (camera_widget, ‘value’), transform=bgr8_to_jpeg)
create widgets
dataset_widget = ipywidgets.Dropdown(options=DATASETS, description=‘dataset’)
category_widget = ipywidgets.Dropdown(options=dataset.categories, description=‘category’)
count_widget = ipywidgets.IntText(description=‘count’)
save_widget = ipywidgets.Button(description=‘add’)
manually update counts at initialization
count_widget.value = dataset.get_count(category_widget.value)
sets the active dataset
def set_dataset(change):
global dataset
dataset = datasets[change[‘new’]]
dataset_widget.observe(set_dataset, names=‘value’)
update counts when we select a new category
def update_counts(change):
count_widget.value = dataset.get_count(change[‘new’])
category_widget.observe(update_counts, names=‘value’)
save image for category and update counts
def save(c):
dataset.save_entry(camera.value, category_widget.value)
save_widget.on_click(save)
data_collection_widget = ipywidgets.VBox([
ipywidgets.HBox([camera_widget]), dataset_widget, category_widget, count_widget, save_widget
display(data_collection_widget)
print(“data_collection_widget created”)
Model
Execute the following cell to define the neural network and adjust the fully connected layer (fc) to match the outputs required for the project. This cell may take several seconds to execute.
import torch
import torchvision
device = torch.device(‘cuda’)
ALEXNET
model = torchvision.models.alexnet(pretrained=True)
model.classifier[-1] = torch.nn.Linear(4096, len(dataset.categories))
SQUEEZENET
model = torchvision.models.squeezenet1_1(pretrained=True)
model.classifier[1] = torch.nn.Conv2d(512, len(dataset.categories), kernel_size=1)
model.num_classes = len(dataset.categories)
RESNET 18
model = torchvision.models.resnet18(pretrained=True)
model.fc = torch.nn.Linear(512, len(dataset.categories))
RESNET 34
model = torchvision.models.resnet34(pretrained=True)
model = model.to(device)
model_save_button = ipywidgets.Button(description=‘save model’)
model_load_button = ipywidgets.Button(description=‘load model’)
model_path_widget = ipywidgets.Text(description=‘model path’, value=‘my_model.pth’)
def load_model(c):
model.load_state_dict(torch.load(model_path_widget.value))
model_load_button.on_click(load_model)
def save_model(c):
torch.save(model.state_dict(), model_path_widget.value)
model_save_button.on_click(save_model)
model_widget = ipywidgets.VBox([
model_path_widget,
ipywidgets.HBox([model_load_button, model_save_button])
display(model_widget)
print(“model configured and model_widget created”)
Live Execution
Execute the cell below to set up the live execution widget. This cell should only take a few seconds to execute.
import threading
import time
from utils import preprocess
import torch.nn.functional as F
state_widget = ipywidgets.ToggleButtons(options=[‘stop’, ‘live’], description=‘state’, value=‘stop’)
prediction_widget = ipywidgets.Text(description=‘prediction’)
score_widgets =
for category in dataset.categories:
score_widget = ipywidgets.FloatSlider(min=0.0, max=1.0, description=category, orientation=‘vertical’)
score_widgets.append(score_widget)
def live(state_widget, model, camera, prediction_widget, score_widget):
global dataset
while state_widget.value == ‘live’:
image = camera.value
preprocessed = preprocess(image)
output = model(preprocessed)
output = F.softmax(output, dim=1).detach().cpu().numpy().flatten()
category_index = output.argmax()
prediction_widget.value = dataset.categories[category_index]
for i, score in enumerate(list(output)):
score_widgets[i].value = score
def start_live(change):
if change[‘new’] == ‘live’:
execute_thread = threading.Thread(target=live, args=(state_widget, model, camera, prediction_widget, score_widget))
execute_thread.start()
state_widget.observe(start_live, names=‘value’)
live_execution_widget = ipywidgets.VBox([
ipywidgets.HBox(score_widgets),
prediction_widget,
state_widget
display(live_execution_widget)
print(“live_execution_widget created”)
Training and Evaluation
Execute the following cell to define the trainer, and the widget to control it. This cell may take several seconds to execute.
BATCH_SIZE = 8
optimizer = torch.optim.Adam(model.parameters())
optimizer = torch.optim.SGD(model.parameters(), lr=1e-3, momentum=0.9)
epochs_widget = ipywidgets.IntText(description=‘epochs’, value=1)
eval_button = ipywidgets.Button(description=‘evaluate’)
train_button = ipywidgets.Button(description=‘train’)
loss_widget = ipywidgets.FloatText(description=‘loss’)
accuracy_widget = ipywidgets.FloatText(description=‘accuracy’)
progress_widget = ipywidgets.FloatProgress(min=0.0, max=1.0, description=‘progress’)
def train_eval(is_training):
global BATCH_SIZE, LEARNING_RATE, MOMENTUM, model, dataset, optimizer, eval_button, train_button, accuracy_widget, loss_widget, progress_widget, state_widget
try:
    train_loader = torch.utils.data.DataLoader(
        dataset,
        batch_size=BATCH_SIZE,
        shuffle=True
state_widget.value = ‘stop’
train_button.disabled = True
eval_button.disabled = True
time.sleep(1)
if is_training:
model = model.train()
else:
model = model.eval()
while epochs_widget.value > 0:
i = 0
sum_loss = 0.0
error_count = 0.0
for images, labels in iter(train_loader):
# send data to device
images = images.to(device)
labels = labels.to(device)
if is_training:
# zero gradients of parameters
optimizer.zero_grad()
# execute model to get outputs
outputs = model(images)
# compute loss
loss = F.cross_entropy(outputs, labels)
if is_training:
# run backpropogation to accumulate gradients
loss.backward()
# step optimizer to adjust parameters
optimizer.step()
# increment progress
error_count += len(torch.nonzero(outputs.argmax(1) - labels).flatten())
count = len(labels.flatten())
i += count
sum_loss += float(loss)
progress_widget.value = i / len(dataset)
loss_widget.value = sum_loss / i
accuracy_widget.value = 1.0 - error_count / i
        if is_training:
            epochs_widget.value = epochs_widget.value - 1
        else:
            break
except e:
    pass
train_button.disabled = False
eval_button.disabled = False
state_widget.value = ‘live’
train_button.on_click(lambda c: train_eval(is_training=True))
eval_button.on_click(lambda c: train_eval(is_training=False))
train_eval_widget = ipywidgets.VBox([
epochs_widget,
progress_widget,
loss_widget,
accuracy_widget,
ipywidgets.HBox([train_button, eval_button])
display(train_eval_widget)
print(“trainer configured and train_eval_widget created”)
Display the Interactive Tool!
The interactive tool includes widgets for data collection, training, and testing.
tool key
tool key
Execute the cell below to create and display the full interactive widget. Follow the instructions in the online DLI course pages to build your project.
[1]:
Combine all the widgets into one display
all_widget = ipywidgets.VBox([
ipywidgets.HBox([data_collection_widget, live_execution_widget]),
train_eval_widget,
model_widget
display(all_widget)
NameError Traceback (most recent call last)
in
1 # Combine all the widgets into one display
----> 2 all_widget = ipywidgets.VBox([
3 ipywidgets.HBox([data_collection_widget, live_execution_widget]),
4 train_eval_widget,
5 model_widget
NameError: name ‘ipywidgets’ is not defined
