RTSP Could not open resource for reading
Orin Jetpack 5.0.2
Setting up RTSP server with:
$ ./test-launch “v4l2src device=/dev/video0 ! video/x-raw, width=640,height=480,format=(string)YUY2,framerate=30/1 ! queue ! nvvidconv ! video/x-raw(memory:NVMM),width=640,height=480,format=(string)NV12 ! nvv4l2h264enc bitrate=912000 ! video/x-h264, stream-format=(string)byte-stream ! rtph264pay name=pay0 pt=96”
stream ready at rtsp://127.0.0.1:8554/test
Note: I’m not seeing the blue lights on the camera that I normally see. However, when I run
the jetson-inference video-viewer, camera works as I expected:
$ video-viewer /dev/video0 rtsp://127.0.0.1:8554 --input-codec=mjpeg --output-codec=mjpeg --bitrate=1000000
Check network to ensure test-launch process is running:
$sudo ss -ltnp
State        Recv-Q   Send-Q      Local Address:Port    Peer Address:Port    Process
LISTEN       0        5           127.0.0.1:8554        0.0.0.0:*            users:(("test-launch",pid=8748,fd=4))
Reading from port:
steven@development-orin:~$ gst-launch-1.0 rtspsrc location=rtsp://127.0.0.1:8554/test latency=0 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvidconv ! xvimagesink sync=0
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://127.0.0.1:8554/test
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not open resource for reading and writing.
Additional debug info:
gstrtspsrc.c(7893): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
Failed to connect. (Generic error)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
Any ideas? Thanks!!!
May be because you’re streaming RTPH264 but you’re trying to read as if it was RTPH265.
Try on receivert side:
If this doesn’t work out, post the formats of your camera with:
# v4l2-ctl is provided by apt package v4l-utils
v4l2-ctl --list-formats-ext
[1]: 'H264' (H.264, compressed)
			Interval: Discrete 0.033s (30.000 fps)
			Interval: Discrete 0.042s (24.000 fps)
			Interval: Discrete 0.050s (20.000 fps)
			Interval: Discrete 0.067s (15.000 fps)
			Interval: Discrete 0.100s (10.000 fps)
			Interval: Discrete 0.133s (7.500 fps)
			Interval: Discrete 0.200s (5.000 fps)
		Size: Discrete 1920x1080
Modified previous entry with code change to 264, still has issue. Thanks for the help.
With H264 format, you may try:
./test-launch “v4l2src device=/dev/video0 ! video/x-h264, width=640, height=480, framerate=30/1 ! queue ! h264parse ! rtph264pay name=pay0 pt=96”
Response:
steven@development-orin:~/Projects/test-gstreamer-video/build/bin$ ./test-launch v4l2src device=/dev/video0 ! video/x-h264, width=640, height=480, framerate=30/1 ! queue ! h264parse ! rtph264pay name=pay0 pt=96
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0: Could not open resource for reading.
gstrtspsrc.c(6232): gst_rtspsrc_setup_auth (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0:
No supported authentication protocol was found
Note that you omitted the double quotes for test-launch.
First try to read camera feed and display (assuming you have a local monitor and GUI running on Jetson).
Try the following command and post the output of the first failing one if any.
gst-launch-1.0 -v v4l2src device=/dev/video0 ! fakesink
gst-launch-1.0 -v v4l2src device=/dev/video0 ! video/x-h264, width=640, height=480, framerate=30/1 ! fakesink
gst-launch-1.0 -v v4l2src device=/dev/video0 ! video/x-h264, width=640, height=480, framerate=30/1 ! h264parse ! nvv4l2decoder ! nvvidconv ! autovideosink
Re-ran test-launch with double quotes. Result seems the same. But I will include for now on.
Ran the 3 tests. All functioned correctly. The last one displayed video on my screen.
That’s good news. Now try:
gst-launch-1.0 -v v4l2src device=/dev/video0 ! video/x-h264, width=640, height=480, framerate=30/1 ! h264parse ! rtph264pay name=pay0 pt=96 ! fakesink
If this runs, you may have the server running in one terminal:
./test-launch "v4l2src device=/dev/video0 ! video/x-h264, width=640, height=480, framerate=30/1 ! h264parse ! rtph264pay name=pay0 pt=96"
and in second terminal run the client:
gst-play-1.0 rtsp://127.0.0.1:8554/test
When client connects, post errors if any from the first terminal (server) and from second terminal (client).
The first test was successful
When I ran the 2nd test I received the standard “stream ready at rtsp://127.0.0.1:8554/test”
The 3rd test had issues:
steven@development-orin:~$ gst-play-1.0 rtsp://127.0.0.1:8554/test
Press 'k' to see a list of keyboard shortcuts.
Now playing rtsp://127.0.0.1:8554/test
Pipeline is live.
ERROR Could not open resource for reading. for rtsp://127.0.0.1:8554/test
ERROR debug information: gstrtspsrc.c(6232): gst_rtspsrc_setup_auth (): /GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0/GstRTSPSrc:source:
Reached end of play list.
@DaneLLL Are you aware of a bug preventing ORIN RTSP?
Any suggestions?
I set
$ export GST_DEBUG=“*:6” then
re-ran
$ ./test.launch “pipeline” 2>err.text
Reviewed the output, nothing eventful shows. I didn’t mention this before, the camera lights show during the gst-launch-1.0 test but not when using ./test.launch.
I submitted a question at freedesktop.org forum 1016 and submitted the error output. I was initially asked to upgrade gstreamer.
I investigated on the Nvidia forums on the process, but seems going past Gstreamer 1.16.3 is not supported.
Works now.
I had changed the receiving object name in test-launch from “test” to “my_stream”. Once I changed back and re-compiled, then ran both, a window with video appeared.
