• Hardware Platform Jetson Xavier NX 16 GB
• DeepStream Version 6.1.1
• JetPack Version 5.02
• Issue Type question
I have got four input rtsp sources. One of them has to be rotated (90 degrees clockwise), so that width is 1080 and height 1920.
What is the best way to do this, in order to stream mux it properly?
Regards
Stefan
jocover
2
nvvidconv
flip-method : video flip methods
flags: readable, writable, controllable
Enum “GstNvVideoFlipMethod” Default: 0, “none”
(0): none - Identity (no rotation)
(1): counterclockwise - Rotate counter-clockwise 90 degrees
(2): rotate-180 - Rotate 180 degrees
(3): clockwise - Rotate clockwise 90 degrees
(4): horizontal-flip - Flip horizontally
(5): upper-right-diagonal - Flip across upper right/lower left diagonal
(6): vertical-flip - Flip vertically
(7): upper-left-diagonal - Flip across upper left/lower right diagonal
yuweiw
4
