RTSP stream transmission using gstreamer
I’m using the given below command to stream from my jetson to my display system (imx8) where both the boards are connected via ethernet cable.
Gst-launch-1.0 videotestsrc ! nvvidconv ! nvv4l2h264enc ! rtph264pay config-interval=1 pt=96 ! Udpsink host=192.168.100.10(imx8 ip) port=5555
This command is sending rtp packets over udp. I want to use rtsp instead of rtp, so what are the changes i need to do.
at the receiver end i’m using the given below command
Gst-launch-1.0 udpsrc port=5555 caps=“application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264” ! rtph264depay ! h264parse ! decodebin ! Autovideosink sync=false
is there any change that i need to do here as well
thank you
Please try to launch RTSP server through test-launch and receive it with rtspsrc plugin. Please refer to
Jetson AGX Orin FAQ
Q: Is there any example of running RTSP streaming?
