Hi
i need to take rtsp stream without encoder
how can i take the stream
i want to stream via ethernet in same network
hardware encoder is not present
Could you please elaborate a bit more.
- What do you want to achieve?
- Are you using GStreamer?
- Do you want to stream from the Jetson device into a PC or another device?
regards,
Andrew
support@proventusnova.com
You may check
Jetson AGX Orin FAQ
Q: Is there any example of running RTSP streaming?
Q: Is there an example for running UDP streaming?
And need to use software encoder x264enc plugin
without software encoder is it possible
You may check this and try:
UDP-Raw Stream Issue On Nvidia Jetson Devices - #8 by DaneLLL
We don’t suggest it since the bottleneck will be in network bandwidth.
