run NVENC sample code failed in LINUX platform
gtx 650ti
the NVENC sample code run smooth in windows 7 64bits but failed in linux.
centos 6.4 Linux 64bits
driver: 337.19
nvenc_3.0_linux_sdk
nvenc_3.0_linux_sdk/Samples/nvEncodeApp/:./1080p_heavyhand_3sec.sh
GetNumberEncoders() has detected 1 CUDA capable GPU device(s) <<
[ GPU #0 - < GeForce GTX 650 Ti > has Compute SM 3.0, NVENC Available ]
InitCUDA() has detected 1 CUDA capable GPU device(s)<<
[ GPU #0 - < GeForce GTX 650 Ti > has Compute SM 3.0, Available NVENC ]
Select GPU #0 - < GeForce GTX 650 Ti > supports SM 3.0 and NVENC
nvEncoder Error: NVENC H.264 encoder initialization failure! Check input params!
Have you managed to solve the problem?
Did you find a solution?
