Running accelerated gstreamer in non-privileged docker container
we are trying to use the accelerated gstreamer on a Jetson Xavier from inside a non-privileged docker container. In detail, we are running a plain Ubuntu 18.04 where only they apply_binaries.sh step has been run and nothing else.
We then create a docker image based on Ubuntu:18.04 and install the nvidia-gst librariers and gstreamer. The resulting containers works fine if it is started with root-privileges but fails to run correctly without with the following errors:
Error: Can't initialize nvrm channel
Couldn't create ddkvic Session: Cannot allocate memory
nvbuf_utils: Could not create Default NvBufferSession
Is there a way to run avoid these errors when running in unprivileged mode?
Cheers
Arnim
We have other user share experiences. Please check
[url]hw video encoding support in a container? - Jetson TX2 - NVIDIA Developer Forums
[url]hw video encoder needs to be initialized on the host before it can be used in a container? - Jetson TX2 - NVIDIA Developer Forums
Thank you, I will give that a go
In the end it is as easy as not using nvidia-docker2 and just exposing these devices to the container:
Ansible:
  • docker_container:
    devices:
    - /dev/nvhost-ctrl
    - /dev/nvhost-ctrl-gpu
    - /dev/nvhost-prof-gpu
    - /dev/nvmap
    - /dev/nvhost-gpu
    - /dev/nvhost-as-gpu
    - /dev/nvhost-vic
    - /dev/tegra_dc_ctrl
