I am seeing some strangeness related to running older docker images on newer jetpack versions.
I have a docker image based on nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples and I want to run it on Jetpack 4.6.
When I try to run our deepstream app it it seems to want to find libnvinfer.so.7.1.3. This appears to have a zero size in the filesystem inside the docker, and does not exist at all outside on the host. The file libnvinfer.so has a simlink to libnvinfer.so.8.0.1on the host Jetpack 4.6.
Is there a dependency on Deepstream docker versions vs Jetpack 4.6 versions? I think the nvidia docker runtime does some funky things like mapping external libraries in so that might mean there is a dependency, however I think this goes against the point of docker to have all the dependencies inside?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Try to run an example using the nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples container on any jetson running Jetpack 4.6
Requirement: Answer the following question:
Is there a dependency on Deepstream docker versions vs Jetpack versions? Do you need to run a specific deepstream docker that matches a specific Jetpack version?
