Running Llama3.1 on JP5.1
I’m trying to run Llama 3.1 on Jetson AGX orin running on JP5.1. I’ve tried MLC but I found out that the MLC image for JP5.1 does not support it. Are there any alternatives to do this?
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Do you run it with HF transformer?
If so, could you try dustynv/llama-factory to see if it works?
The container already includes Transformers, FlashAttention, bitsandbytes, AutoGPTQ, vLLM.
I was trying to use either MLC or Ollama.
Do you have an example to use dustynv/llama-factory?
BTW, It seems it’s for fine-tuning. What I need is an inference engine.
Thanks,
The dustynv/llama-factory supports the HF transformer.
For example, you can run InternVL2 with the instructions in the model card:
We also have MLC and Ollama prebuilt containers:
Please find it below:
MLC: jetson-containers/packages/llm/mlc at master · dusty-nv/jetson-containers · GitHub
Ollama: jetson-containers/packages/llm/ollama at master · dusty-nv/jetson-containers · GitHub
Hi @pcha , I tried rebuilding MLC for JetPack 5.1, but was encountering compliation issues from the older CUDA version:
I would recommend trying previous MLC versions or trying to patch the errors (although that may be a losing battle)
If you are on AGX Orin, you can compile MLC through the jetson-containers builder, but I would recommend upgrading to JetPack 6 if possible, if you need to keep current with genAI libraries.
You can easily build/run llama.cpp or ollama on JetPack 5 and run llama 3.1 with quantization, but it will be roughtly ~65% the performance you would have gotten from the likes of MLC or TRT-LLM.
