Failed to MLC-compile mlc-ai/Llama-3.1-8B-Instruct-fp8-MLC on Jetson AGX orin
I’ve tried using mlc-ai/Llama-3.1-8B-Instruct-fp8-MLC on Jetson AGX orin but it fails at the compilation step.
I’ve raised an issue in MLC community but I’m posting it here as well hoping if I could get an insight from Jetson side.
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Please find below for a sample to run MLC on the Orin.
I’ve verified that it’s working with quantization=q416_ft but not with 8bit quantization methods.
It fails at the compilation step
It looks like the model can work with q4 but fails with 8-bit quantization.
So the failure might be caused by the model requiring more memory resources than the Jetson device has.
You can verify this by monitoring the system with tegrastats:
$ sudo tegrastats
