Running taov5 on azure ml studio
Hardware - GPU (A100/A30/T4/V100) - V100
Hardware - CPU
Operating System
Riva Version
TLT Version (if relevant)
How to reproduce the issue ? (This is for errors. Please share the command and the detailed log here)
when i try to run tao model yolov4 dataset_convert command it fails as so below
WARNING:tensorflow:TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
2024-07-27 22:00:42,118 [TAO Toolkit] [WARNING] tensorflow 42: TensorFlow will not use Dask by default. This improves performance in some cases. To enable Dask export the environment variable TF_ALLOW_IOLIBS=1.
WARNING:tensorflow:TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
2024-07-27 22:00:42,123 [TAO Toolkit] [WARNING] tensorflow 43: TensorFlow will not use Pandas by default. This improves performance in some cases. To enable Pandas export the environment variable TF_ALLOW_IOLIBS=1.
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/scripts/dataset_convert.py”, line 48, in
raise e
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/yolo_v4/scripts/dataset_convert.py”, line 32, in
main(sys.argv[1:])
File “/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/dataset_convert.py”, line 129, in main
merge_text_proto(f.read(), dataset_export_config)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 719, in Merge
return MergeLines(
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 793, in MergeLines
return parser.MergeLines(lines, message)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 818, in MergeLines
self._ParseOrMerge(lines, message)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 837, in _ParseOrMerge
self._MergeField(tokenizer, message)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 967, in _MergeField
merger(tokenizer, message, field)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 1042, in _MergeMessageField
self._MergeField(tokenizer, sub_message)
File “/usr/local/lib/python3.8/dist-packages/google/protobuf/text_format.py”, line 932, in _MergeField
raise tokenizer.ParseErrorPreviousToken(
google.protobuf.text_format.ParseError: 4:3 : Message type “COCOConfig” has no field named “images_dir_names”.
my coco_config looks like this
coco_config {
root_directory_path: “/home/azureuser/sudhee_tao_experiments/project/data/OP”
images_dir_names: [“train”, “val”]
annotation_files: [“annotations/OP_combined_coco_train.json”, “annotations/OP_combined_coco_val.json”]
num_partitions: 3
num_shards: [1, 72, 2]
image_directory_path: “/home/azureuser/sudhee_tao_experiments/project/data/OP/images”
