Problem: Runtime D3 showing as Not Supported on Fedora Linux with RTX 2070 SUPER Max-Q and i7-9750H according to /proc/driver/nvidia/gpus/0000:01:00.0/power
Yes, I set “options nvidia NVreg_DynamicPowerManagement=0x02” in /etc/modprobe.d/nvidia.conf when I installed the drivers from negativo17 and rpmfusion’s repository and /sys/bus/pci/devices/0000:01:00.0/power/control is set to auto by default it seems.
Then you should look for a bios update, the nvidia driver needs the supplemental acpi methods mentioned. Those should be mandatory reqirements by intel.
