Hi all, and I hope you can give me some pointers.
What I’m after is a simple sample/pilot code that will capture from argus, run through CUDA OpenCV, and then encode, without shuffling frames in memory between CPU and GPU. In other words, hardware decoding into GpuMats, running a filter (I need more, but if I can get this working I’m probably fine), and then hardware encoding back to a file or network connection.
I’ve tried pretty much every sample I could find, and they consistently fail at runtime in ways that suggest, somehow, that CUDA isn’t happy with the memory its being given from the video output. The errors usually look like:
terminate called after throwing an instance of 'cv::Exception'
what(): OpenCV(4.5.4) /home/stuart/opencv_contrib/modules/cudafilters/src/cuda/row_filter.hpp:172: error: (-217:Gpu API call) unspecified launch failure in function 'caller'
which does not give me a whole lot of clues. Even tracing the gstreamer pipeline doesn’t show what’s happening. If I skip running an OpenCV filter, it all completes OK, although creating the filter looks fine.
Having tried that, and continued searching, I found a completely different sample that seems closer, the opencv_nvgstenc sample.
This time, I am getting assertion failures:
OpenCV(4.5.4) /home/stuart/opencv/modules/videoio/src/cap_gstreamer.cpp:1611: error: (-215:Assertion failed) frameSize.width > 0 && frameSize.height > 0 in function 'open'
And yet, this is with a valid width and height passed in. This is definitely frustrating as it looks like this sample might do exactly what I need. (Except not really, because even here, it’s using Mat rather than GpuMat, which is what I’m after.]
I’ve attached the samples I’ve been trying to get working.
gst_cv_gpumat.cpp (4.3 KB)
opencv_gst_encoder.cpp (6.1 KB)
I know this is a common use case, because I see a lot of questions asking this in one form or another, but each resolution seems to be slightly different, and I can’t get them working (I’m not a CUDA expert). All I want is to get some proof of concept that OpenCV on CUDA can actually run on GpuMats between an accelerated decoder and an accelerated encoder.
Does anybody have a hints and tips?
