Saving Animations as Clips and Playing them through Action graph
Good Day,
I have created a Position and Rotation based animation in the Curve editor and Timeline.
I am not able to proceed further on saving that animation as an Animation clip and playing it through the Action graph.
I can see a Push graph that is getting created but I don’t want that to play Automatically in Play mode.
Goal : Create animations using Timeline and Save them as Animation clips for later use.
You can try just baking out the animation. Time sample playback should be faster.
# convert OV curve to time sample
import omni.anim.curve as curve_api
from omni.timeline import get_timeline_interface
curve_iface = curve_api.acquire_interface()
timeline_interface = get_timeline_interface()
prim = stage.GetPrimAtPath("/World/Cone")
time_codes_per_second = stage.GetTimeCodesPerSecond()
anim_curve_names = curve_api.get_curves(prim)
# go through all the animation curves on the prim
for curve_name in anim_curve_names:
	if curve_name:
		keys = curve_api.get_keys(prim, curve_name)
		key_times = [curve_api.key_time_to_time_code(key.time) for key in keys]
		curve_start_key = key_times[0]
		curve_end_key = key_times[-1]
		attr = prim.GetAttribute(curve_name.rsplit(":", 1)[0])
		# bake out time samples on the translate X curve from first key to last
		for frame in range(int(curve_start_key), int(curve_end_key+1)):
			timeline_interface.set_current_time(frame/time_codes_per_second)
			curve_tx = curve_iface.evaluate("/World/Cone.xformOp:translate:x", frame/stage.GetTimeCodesPerSecond())
			print(curve_tx, frame)
			attr.Set(Gf.Vec3d(curve_tx, 0, 0), Usd.TimeCode(frame))
Also here an example usd that shows an animation clip being triggered by actiongraph. Just press the “1” key
actiongraph animation2.usd (22.5 KB)
Thank you so much for sharing this Sample, The Curve Graph suited my purpose.
Great thanks !
