Hey guys,
i want to control a LED Stripe (12V … max. 300mA) with a Jetson Nano 2GB DevKit GPIO Pin.
This is my schematic:
I am a little bit confused about the current draw of a GPIO pin. Some people write its ± 1mA other say 20uA.
If you look at my schematic … Should i choose another value for R1? Is that schematic even possible with a GPIO pin? Any other suggestions how to drive that N-Ch Mosfet ?
Thanks in advance!
Artur
The GPIO pins of 40-pin connector all pass through a level shift, PI4ULS5V108LEX. So you can find its output characters in datasheet: https://www.diodes.com/assets/Datasheets/PI4ULS5V108.pdf
you say it is a P14ULS5V108LEX, but on this site its the Texas Instruments TXB0108RGYR level shifter.
https://developer.nvidia.com/embedded/learn/jetson-nano-2gb-devkit-user-guide
Which one is the right one on the 2GB DevKit?
Checked again, it should be TXB0108, please follow that GPIO usage consideration and its datasheet online.
