I had connected the touchscreen LCD ‘WaveShare 7 inch HDMI LCD(C)’ to the JETSON NANO Board, and we found that there is a problem that the screen resolution cannot change to 1024 * 600.
Also, I can’t change the screen resolution to 1024 * 600 even we put ‘xrandr’ in the terminal.
How can I change the screen solution to 1024 * 600? And how can I fix the screen resolution to 1024 * 600 when the JETSON NANO Board is turned on?
FYI, there is no problem when I connected the touch screen to raspberry pi.
Screen 0: minimum 8 x 8, current 1280 x 720, maximum 16384 x 16384
HDMI-0 connected primary 1280x720+0+0 (normal left inverted right x axis y axis) 890mm x 500mm
1280x720 60.00*+ 59.94 50.00
720x576 50.00
720x480 59.94
640x480 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
