I’m looking at the Jetson Linux developer guide using Chrome.
It is inconvenient because there is a phenomenon that the document returns to the beginning when scrolling.
Can you improve it?
Thank you.
Can you improve it?
Thank you.
I can scroll up and down without seeing the issue. It can keep at the place. Here is my Chrome version:
Version 86.0.4240.111 (Official Build) (64-bit)
FYR.
version 86.0.4240.111(official build) (64bit)
If you are looking at the document, problems arise.
Thank you.
Could you try Firefox or Edge? We are not able to observe the phenomenon, so if other browser can work well, you can use the browser.
Yes.
Thank you.
I know that the latest jetson linux developer guide can be found in the following image. Is it correct? If correct
Can I download a pdf that reflects the latest content?
Thank you.
We would suggest go to
We miss to upgrade the version since there is no modification between r32.4.3 and r32.4.4 in developer guide. For deviation between r32.4.3 and r32.4.3, please take a look at Release Notes
